Check engine light on uphill
Old Jun 8, 2023 | 08:13 PM
raydav's Avatar
raydav
Can anyone point me to the algorithm that activates the check engine light. I have only a correlation. If I work it hard going up a hill, the light comes on. When I coast down the other side, the light goes off. Engine and trans temp does not change. I never leaves an error message.
Old Jun 8, 2023 | 08:20 PM
Walleye Hunter's Avatar
Walleye Hunter
If it's chipped, something does that. Might be overboost on the manifold pressure. If it's not chipped, then something else is going on.
Old Jun 8, 2023 | 08:50 PM
raydav's Avatar
raydav
Not "chipped"
MAP as high as 29. Light does not immediately go on or off with MAP change.
Somewhere there is a bit of code that controls this. Where/what is it?
Old Jun 8, 2023 | 09:06 PM
97-psd's Avatar
97-psd
Can you read live data from the truck? If it is under load while it happens, it could a high pressure oil issue that pops the code.
Old Jun 8, 2023 | 09:33 PM
cleatus12r's Avatar
cleatus12r
Butt-Head
It's probably either overboost or low injection pressure....but we're all just throwing stones in a pool without a code.
Read the code.
Old Jun 9, 2023 | 02:32 AM
carl2591's Avatar
carl2591
I get that as well when pulling hard up hill with tuner in 60 HP tow tune.. have check codes during and after and no code at least on torque app i can find. have a boost fooler on but it still does it..
have checked HP oil pressure and its steady the whole time.. now i just down shift and let her rip.. 2-2200 is the sweet spot.. pulls like a freight train.. loving it here on alaskan highway,, but not liking all the frost heaves west of destruction bay.. OOOMMMGG.. some are like foot and half high.. WOW.. heading to Tok and Delta junction to get my certificate for surviving the alcan..
PS its midnight and still LIGHT out..
Old Jun 9, 2023 | 07:09 AM
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
TorquePro app is terrible at everything except looking pretty, when it works that is. Get FORScan Lite for $5 or PC version for free and check the codes again, it will be there.
Old Jun 9, 2023 | 08:58 PM
raydav's Avatar
raydav
I have AutoEnginuity. $150 for the basic and another $300 for the add-on. It doesn't produce codes, it produces text.
And two quad, live display units whose brand escapes me at the moment.
I'll try looking at some other things live.
But I really want the algorithm. Is it impossible to know what is in the computer?
Old Jun 9, 2023 | 09:30 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
You need the codes if you want to fix this. Get Forscan.
There are many algorithms that turn on the check engine light. There are probably about 70 or so codes that can turn it on, and each one has it's own set of algorithms.
Old Jun 10, 2023 | 12:17 AM
Wes444's Avatar
Wes444
Sorry, but saying you have AE is akin to saying, but I prefer to use DOS after the iphone 24Super+ came out. You're talking technology that was dated over 10 years ago. Yes it's better than only knowing that the engine light is on, but it can't do what the current apps can do.
Like Sous said, if Torque even decides to work, it looks pretty, until it randomly shuts off the motor for no reason while driving down the highway and then self deletes all your pretty screen settings and pids and reverts to factory setup. For troubleshooting and logging tho, use the humble looking and free forscan
Old Jun 10, 2023 | 06:33 AM
Sous's Avatar
Sous
FTE Emeritus
If a code was set, FORScan will retrieve it.
Start with the last link, the Q&A.
FORScan
Old Jun 10, 2023 | 08:22 PM
raydav's Avatar
raydav
I have been reading injection control pressure, I think that is what it is called. It is a five digit number, and the first two digits kinda track the two digit MAP.
Gwilkrrs
Jan 21, 2022 08:26 AM
Blarouche
Jan 3, 2017 05:15 PM
ugh3012
Modular V8 (4.6L, 5.4L)
May 22, 2016 06:40 PM
