Ticking from engine
Old May 23, 2023 | 09:42 AM
Masteraj1's Avatar
Masteraj1
6th Gear
Ticking from engine
Hey all been driving my 91 f250 7.5 gas 4x4 now as a daily driver for a week. Noticed this morning there is a ticking noise coming from the engine on passenger side. Any ideas? The sound is in sync with the the RPMs. So when I give it more throttle the ticking noise speeds up.
I pulled codes and got the following.
77 R
74 R
65 R
Old May 23, 2023 | 10:16 AM
Prototypemech's Avatar
Prototypemech
Could be a leaking or cracked exhaust manifold, or a stuck hydraulic lifter that's not pumping up. Could also be a AIR injection pump that is failing.
Old May 23, 2023 | 10:18 AM
Masteraj1's Avatar
Masteraj1
6th Gear
I think you may be onto something with the exhaust manifold. Wondering about degree of difficulty to replace this?
Old May 23, 2023 | 02:34 PM
Prototypemech
Exhaust manifolds are pretty easy. The gasket is cheap. Just make sure you soak the fasteners overnight with pb blaster before you get started. The bolts have a tendency to snap off when trying to remove them.
Old May 24, 2023 | 01:16 AM
mikekozak's Avatar
mikekozak
Does the gasket work with the original manifold? So far as I thought, the original manifolds are not gasketed.
Old May 24, 2023 | 11:46 AM
Prototypemech
Yes. You can buy gaskets for the exhaust manifolds. They came from the factory without gaskets. Felt pro makes a nice gasket for that engine.
Old May 24, 2023 | 12:04 PM
My4Fordtrucks's Avatar
My4Fordtrucks
Originally Posted by Prototypemech
Exhaust manifolds are pretty easy…..The bolts have a tendency to snap off when trying to remove them.
Once you move other stuff out of the way and if all the bolts come out that have been there for 30+ years.
True but they were both were freshly machined surfaces. After years of heat cycles it will need a gasket to seal.
Old May 24, 2023 | 02:01 PM
96150's Avatar
96150
I'm having the same issue with my truck actually. Mine is a 96 f150 4x2 with the 4.9L. For me it ticks high when started and then less when warmed up but much louder and slower when in gear. I have pulled my manifolds and am going to replace the gasket. Good luck with yours
Old Jun 21, 2023 | 07:18 AM
Masteraj1's Avatar
Masteraj1
6th Gear
I’m pretty sure it’s the lifter now. I see on rock auto they have a camshaft and lifter kit.
https://www.rockauto.com/en/catalog/...534476c1124479
Guess it would make sense to replace all lifters at the same time.
curious about degree of difficulty doing this and if I anything else should be done concurrently with the camshaft/lifter job since the engine would be opened up?
im sure there would be vacuum hoses I’d be moving out the way as well to do this job and maybe do those too?
Old Jun 22, 2023 | 07:53 AM
FuzzFace2's Avatar
FuzzFace2
Timing chain when doing the cam & lifters
You did not say how many miles on the motor?
Dave ----
Old Jun 22, 2023 | 08:09 AM
Masteraj1's Avatar
Masteraj1
6th Gear
Dave ----
trucks at 217000 miles
Old Jun 22, 2023 | 08:48 AM
FuzzFace2's Avatar
FuzzFace2
Well if the chain has not been done yet I would say you are on barrowed time.
I have a motor with 277+ on it but the chain was changed when the timing cover had a coolant leak think around 100K.
It did not have a lot of play but we (dealer) were there so it was done.
Dave ----
bigtexan99
Nov 21, 2022 05:18 PM
clintbonnie
May 4, 2022 01:04 PM
r-kid
Jun 17, 2011 04:38 AM
modog
Apr 3, 2004 11:44 PM
