using a 73-77 radiator support
Old May 22, 2023 | 03:59 PM
67nukeford's Avatar
67nukeford
Veteran: Navy
Exclamation using a 73-77 radiator support
Guys, I have a 73-77 radiator support that I would like to use for my 67. But, I know the light mounting hardware is different, and I'm wondering if the headlights will be in the right position with the 68 grill I have. So, wondering, for you guys that have done this, is that the case?
Thanks!
Old May 22, 2023 | 07:23 PM
emeraldcoupe's Avatar
emeraldcoupe
i put a dent support on my 71, all the 71 parts bolted on just fine. not sure if that helps.
Old May 23, 2023 | 08:44 AM
Green72F250's Avatar
Green72F250
You may have seen this before but here it is just in case you haven't: The Great Radiator Support Swap - FORDification.com
Old May 23, 2023 | 03:58 PM
67nukeford's Avatar
67nukeford
Veteran: Navy
that helps, thanks man!
Awesome! I was going to search the FORDification site tonight, but, you saved me time on that, appreciate it!
Old May 23, 2023 | 06:29 PM
67nukeford's Avatar
67nukeford
Veteran: Navy
What about the headlight buckets, and what-not? I know the 73 and up use a different setup.
Old May 23, 2023 | 08:01 PM
emeraldcoupe
I used a 74 support, but not sure I follow, unless the earlier grills are different, but the headlight buckets and all associated parts attach to the grill.
Old May 23, 2023 | 08:14 PM
fe390pc's Avatar
fe390pc
You are correct sir, on the 67 to 72 the lights mount to the grill. I do believe you will need to add a couple of holes though. First is for the hood latch, second is for the lower grill support tabs. Or at least that is what I remember.
Old May 23, 2023 | 08:55 PM
emeraldcoupe
yup, 7 holes to be exact. here's my write up of the swap
dent rad support swap- easy - Ford Truck Enthusiasts Forums (ford-trucks.com)
Old May 24, 2023 | 04:04 PM
67nukeford's Avatar
67nukeford
Veteran: Navy
Ah, that's why I'm confused!! Okay, it's been 11 years since I took the truck apart, so I was thinking they attached to the core support!!! Thanks for setting me straight, guys!
Old May 24, 2023 | 04:05 PM
67nukeford's Avatar
67nukeford
Veteran: Navy
Yeah, I have those all drilled out, it's in the truck now. Just wasn't sure about the lights, but, now I'm straight on that! Time to order parts!!
thanks again for all the feedback guys, appreciate it!
Old May 31, 2023 | 03:08 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
There are TWO different 1967/72 radiator supports.
There are TWO different 1973/78 radiator supports with round headlamps.
Both of the above: The radiator support used with the Super Cooling radiator has a larger opening radius.
Super Cooling radiator: 26 1/4" wide x 24 11/16" high.
Standard, xtra cooling and A/C radiators: 26 1/4" wide x 19 3/4" high.
The fan shrouds are also different.
F100fun
Oct 13, 2021 08:27 AM
kenny nunez
Aug 5, 2017 12:17 PM
tjdad62
Aug 13, 2012 09:03 PM
tude
Nov 1, 2005 05:01 AM
Redj
Jan 7, 2004 08:40 AM
