PCM communication issues
Old May 24, 2023 | 12:38 AM
ford150150's Avatar
ford150150
Thank you Sous.
What should ipr % be while cranking on a good system?
and does my 46% indicate possibly a bad ipr or would it definitely be an oil leak?
Old May 24, 2023 | 01:44 AM
udsuth78's Avatar
udsuth78
Originally Posted by ford150150
Will go over the harness tomorrow when I get off work.
1- would having an electrical issue on just 2 of the cylinders cause a no start condition? I mean in reference to the two Cylinders that were way out of spec.
2- why would the icp being plugged in make the check engine light not stay on (KOEO) like its supposed to?
I've read here that a communication issue w/ even 1 injector can cause the idm to shutdown the entire bank. Is that likely your issue? IDK, but if there is any kind or communication between the pcm and idm that will definitely cause a no start.
ICP unplugged will always throw a light. Not all codes maintain a light until cleared, a lot of codes will only throw a light when the issue is recognized but will turn off shortly after. Sounds like pcm is doing what it's programmed to do in that regard.
Old May 24, 2023 | 01:50 AM
ford150150's Avatar
ford150150
No sir not what im saying.
Normally with the key in the on position - the service engine light will stay illuminated.
If the ICP is plugged in - once you turn the key to the on position - the service engine light comes on for 1 second and then goes out. Which is abnormal as far as i know.
If i go back and unplug it - the light comes back on like its supposed to.
Key on engine off.
Old May 24, 2023 | 01:51 AM
udsuth78's Avatar
udsuth78
Thank you Sous.
Your dc% looks fine to me. That number is directly dependent on the icp and what you and the pcm are asking for at the time. Max dc% w/out tuning is around 67% I think, so if you are seeing it stop climbing at 46% then the pcm is seeing the pressure it wants so no need to push the ipr harder.
Old May 24, 2023 | 05:51 PM
udsuth78's Avatar
udsuth78
Key on engine off.
What are all the gauges and such showing when this happens? I've always assumed the CEL during KOEO was related to oil pressure or something of the sort. You know power is on but don't register pressure ”ding check engine”. Nothing to base that theory on just how I rationalized it to myself. Now I'm curious what does trigger the light to be on before start up and what box gets checked for it to shut off.
Old May 25, 2023 | 09:19 PM
aawlberninf350's Avatar
aawlberninf350
It's a Van Gogh
Sounds like normal operation. When keyed on the dash will briefly illuminate all lamps so you can check if any are burned out. The CEL is included in that. Then the CEL will remain lit only if there is a code stored, or in this case a sensor is disconnected. If the PCM sees all sensors and there are no codes the CEL has no reason to be lit. Only the Check Gages and Battery lamp will remain lit because the alternator is not working with the engine off. Or maybe I am misunderstanding what you are seeing?
The pin numbers you reference above with the giant 600 ohm resistance on pin 6; what connector is that? That resistance looks like a problem.
Old May 30, 2023 | 03:41 AM
ford150150's Avatar
ford150150
I guess i am confusing myself because I always thought even without codes with KOEO the SES would stay illuminated indefinitely. Maybe im just confused with it not coming on at all in reference to the fuel bowl heater.
That is on the IDM connector itself.
OneFifty94
Jan 29, 2022 06:23 PM
CaptainCook1987
Dec 28, 2021 05:11 PM
Marty Queen
2004 - 2008 F150
Feb 9, 2021 12:05 AM
bluemarlin1
May 17, 2020 06:24 AM
Gear
Nov 20, 2019 04:41 PM
