B1681 PATS transceiver module signal is not received by the PCM. This DTC can be caused by the circuits between the PATS transceiver and the PCM, the PATS transceiver, or the PCM. Follow the pinpoint test for diagnosis. This can also be caused by using the incorrect transceiver part number. Make sure that the correct transceiver part number is being used.
