No crank and gear indicator missing
Old May 18, 2023 | 07:10 PM
jkodenski's Avatar
jkodenski
Trailering
Have an 05 f350. Just replaced the motor and now motor will not crank and the gear indicator is missing on the IC. It’s a King Ranch so isn’t the gear indicator a digital highlight?
disconnecting the wire at the right battery and shorting to positive does crank the motor and engine starts with key on. TCM does show correct gear selection with scanner but IC doesn’t show anything. It does show P0117 intermittently and gauge is pegged for temp. Would that preclude engine start?
Old May 18, 2023 | 07:44 PM
bismic's Avatar
bismic
Disconnect the ECT and see what happens. Low resistance means high temprature.
That said, causing a no-crank is a bit of a stretch IMO.
Old May 18, 2023 | 07:57 PM
bismic's Avatar
bismic
FordTechMakuloco posted this once:
Look for a loose shift lever. Shift bushings in the shift lever wear out. Also the shift bracket under the steering column gets loose. All that adds up to a loose shift cable. This can cause a no-crank.
So, will you get a crank with the shift lever in any position? Maybe the Transmission Range Sensor is bad?
Old May 18, 2023 | 08:28 PM
jkodenski's Avatar
jkodenski
Trailering
I’ll look into it starting in any gear. With the PCM/TCM showing the right gear selection, is this still reading from TRS or is that coming from a different source?
Old May 19, 2023 | 12:05 AM
bismic's Avatar
bismic
Good point, and I believe that it should. Just something to keep in mind I guess.
One thing you can do is try to get it in reverse with the key on, and see if you have the backup lights on.
george69
Sep 23, 2022 05:44 PM
tony1947
Apr 4, 2010 11:41 PM
ENCSDEI
May 11, 2007 05:06 PM
inliner
May 17, 2002 11:27 AM
