ETC Light
Old May 18, 2023 | 09:02 PM
BobbytheShooter's Avatar
BobbytheShooter
4wd Low
ETC Light
What’s s the fix for a wrench-shaped electronic throttle control light?
Old May 19, 2023 | 12:17 AM
bismic's Avatar
bismic
What model year do you have? NM - I see your first thread 07. All wrench lights should have a code thrown. Scan for that code number and post. Note that many cheap scan tools can not thoroughly retrieve codes. We recommend ForScan (it is cheap, $35-$40, to buy and set up). There are videos available on YouTube on how to set it up.
There are about a half dozen things that can throw a wrench light:
A PCM detected fault on two of the 3 Accelerator Pedal Position (APP) 3-track potentiometer sensor signals (also called throttle position sensors) only allows the engine to operate at idle. For 05+ model years, it WILL throw a Wrench light: PC/ED manual - page 5-15.
FICM low voltage detection monitor - DTC P0560 stored and wrench warning lamp illuminated when PCM vehicle power (VPWR) is below 10.25V for 60 seconds or below 9V for 4 seconds (DTC P0560) - Wrench light. TSB 09-24-3
(Note - Battery voltage below 9.5V will cause delayed/hard starts. Below 8V (WSM) and it will not start)
Turbocharger over boost detection - Defuel at 28.6 psig boost (possibly need to be at or above 75 mph also) DTC P0234 - Wrench light for 2005 - 2007 F-series engines (and 2008 - 2010 E series) TSB 09-24-3
DTC P012F stored and Wrench warning lamp illuminated when the oil coolers efficiency drops below a specified threshold for a given speed and vehicle load condition - Wrench light. TSB 09-24-3
60DRB
1997 - 2003 F150
Nov 1, 2022 12:34 PM
NeilM67
Oct 19, 2020 01:50 PM
Jerry Chaney
Nov 15, 2016 07:54 AM
woody367
Oct 12, 2007 04:27 PM
emilbolboaca
1983 - 2012 Ranger & B-Series
Nov 28, 2006 08:53 PM
