Throttle Position Sensor Out of Range
I hope you guys are not getting sick of me. I've been working on the truck a lot and got another question.
I have a code 23 Throttle Position Sensor Out of Range (both KOEO and KOER). I backprobed the TPS and am getting about 3 ohms to ground on the black/white wire, 5.1 V reference voltage on the orange wire, and 0.6 V (closed throttle) to 4 V (WOT) on the green wire. This is all with a cheap Harbor Freight multimeter so probably not perfectly accurate.
Are those values indeed out of range? Do I need to replace the TPS or somehow adjust it?
Thanks in advance,
André
Thanks in advance,
André
Jonathan Stone
08-21-2015 03:45 AM
TRUE IMAGE
02-02-2009 02:19 PM
Iron Horseman
06-16-2006 01:42 PM
