Throttle Position Sensor
Old Aug 29, 2009 | 06:51 PM
van1989's Avatar
van1989
I have a 91 7.3 with a e4od I am getting code 63 How do you adjust the sensor? rebuilt engine & tranny
Old Aug 29, 2009 | 08:52 PM
rupejosh's Avatar
rupejosh
on the tps or "fipl" (fuel injection pump lever) ORANGE/WHITE
TEST: With the KEY ON, ENGINE OFF voltage should be approximately 5 volts.
Wire C is the throttle opening signal sent to the computer from the FIPL sensor . TEST With the KEY ON, ENGINE OFF and the throttle at idle position, voltage should be approximately 1.2 volts. With The throttle fully open, voltage should be approximately 4.5 volts. ORANGE/WHITE (CENTER WIRE)
The sweep from 1.2 volts at idle to approximately 4.5 volts at full throttle should be smooth
If the previously described range cannot be attained, FIPL adjustment can be achieved by rotating the sensor (on its bracket) one way or the other until the voltage values are satisfactory.
this is the thread i got it from https://www.ford-trucks.com/forums/4...djustment.html
HotRodTroy
2004 - 2008 F150
May 6, 2014 08:19 PM
rangerbob406
Jan 19, 2013 08:14 PM
Pyancey
Jan 16, 2013 09:08 PM
bh70116
1978 - 1996 Big Bronco
Aug 29, 2010 06:32 PM
lwpman
Apr 28, 2004 08:41 PM
