Hey guys recently bought a 94 f250 for 2k with 103k on the clock. It's got the 5.8 efi and the eod4 I think it's called? Anyways I have an issue with my temp gauge. The needle doesn't go up all the way. You're probably thinking "yeah wait for it to heat up duh" when the engine is cold it sits in the area as if the truck was off. Once it heats up (after a drive etc) it moves up to just below the starting line in the gauge. Od switch is disconnected and fuses checked(originally didn't work at all. Changed the fuse and its doing this) the cluster was rebuilt by the previous owner. More info that may help. The radio has the clock on, however no buttons work. There's no door buzzer either. The battery and fuel gauge work and I'm 70% sure the oil gauge works as well. Any ideas? Do I need to pull the clustee out? Thank you so much!
Alot of times the factory temp gauge will not move very high into the “normal” range unless the motor is overheating. Than it will climb to the high side.
I've heard it said that these gauges aren't the most accurate. Even before the engine swap my temperature gauge sat low and my oil pressure gauge sat high, but I got used to it.
That is the test, ground the wire and the gauge pegs.
Needs a new thermostat?
An infrared temperature thermometer is what I use to check radiator temp and t stat housing temps
Install a capillary tube gauge if you want accuracy.
007
Every hotrod, every time gets one
Are you sure the truck is getting up to temp? Guess you need to know for sure if it’s the instrumentation or if it’s the truck not getting up to operating temp. If it were me, I’d find out what the range on the temp sending unit is…I’m pretty sure it’s just a single wire unit. Then test the resistance. That should give you an idea at least where on the gauge it should show. Then I’d prolly use a temp gun to see how hot the thermostat housing is. Will let you know if it’s getting warm enough…190-200ish. If it were a 96+ I’d check engine coolant temp via obd2. But I don’t know how, or even if it is available to check on an older truck.
