Hot not start
Old May 14, 2023 | 10:42 PM
Tate_B's Avatar
Tate_B
3rd Gear
Hot not start
I have a 2007 f350 6.0 it’s had mild things done here and there but my main issue is a hot no start. When I first start it for the day I crank about 3 times get 700-800 icp and starts great. While driving no lack of power is seen and I maintain spec icp while at idle and driving but after I shut it off the icp will drop while cranking to 500-600 with no start. Dummy plugs stand pipes and ipr have been replaced and HPOP was confirmed good.
Old May 15, 2023 | 12:07 AM
bismic's Avatar
bismic
500-600 ICP is sufficient for a start. Your problem might be elsewhere. Any codes?
How was the HPOP confirmed to be good?
Old May 15, 2023 | 07:40 AM
Tate_B's Avatar
Tate_B
3rd Gear
Hot no start
I unplugged the ficm put 12v to the ipr and read the mechanical gauge i installed getting a reading of 4000 the max of my gauge.
Old May 15, 2023 | 07:46 AM
bismic's Avatar
bismic
So, 4000 psi by cranking at 170(ish) rpm with the IPR actuated closed? Even with a potential leak in the system?
Old May 15, 2023 | 07:47 AM
Tate_B's Avatar
Tate_B
3rd Gear
Yes the ipr was also recently replaced as well
Old May 15, 2023 | 07:58 AM
bismic's Avatar
bismic
Good deal. You need a good code scanner. What are you using now? The issue pretty much can't be in the HPO system.
Millerfarmsva
Sep 24, 2022 04:38 AM
Dlras
6.4L Power Stroke Diesel
Jul 10, 2021 08:05 PM
02GrayPowerStroke
1997 - 2003 F150
Aug 19, 2019 01:16 PM
DieselOwnerNow
Dec 9, 2013 05:57 PM
Trucky2
Sep 23, 2010 06:33 PM
