Sponsored by: Real Truck
Wheel adapters
Old May 17, 2023 | 03:26 PM
LONCO's Avatar
LONCO
Well, I took the easy and suggested way out. I returned the 8 x 6.5 adapters and returned the 8 x 6.5 rims. Then bought the same rims in the 8 x 200 bolt pattern. I will just carry a front spare tire (8x200) and hopefully be able to limp a rear flat tire to a shop if it is only one tire out of the duals.
Old May 18, 2023 | 08:09 AM
speedfreak78's Avatar
speedfreak78
I guess it's a little late, unless you can return those wheels, but i was looking at pics of the SD front DRW adapter. You could've had all the holes welded up and then have the face turned flat and the 8x6.5 pattern put in. Probably would cost about the same, maybe a little more, as 2 new wheels.
You might also be able to have your rims, or at least your spare, drilled with both patterns so they are interchangeable
This place also makes really nice custom adapters. These are the OBS ones but they could make some with the SD hub pattern, 8x6.5 wheel pattern, and whatever thickness you need to fit the rim s you have.
https://torqueking.com/product/42176...5-97-f250-f350
Old May 18, 2023 | 09:36 AM
E-350 SuperDuty 4x4's Avatar
E-350 SuperDuty 4x4
Torque King doesnt make them, they are Arrowcraft. Torque king is merely a distributor of their product.
https://arrowcraftproducts.com/
Old Jul 22, 2023 | 08:56 PM
E-350 SuperDuty 4x4
please delete
AmeriKen
Apr 9, 2023 08:26 PM
crimson5liter
16
Sep 27, 2021 10:30 AM
Liquid10Rider
May 14, 2018 10:17 AM
MMSGuthrie110
Mar 25, 2010 11:53 PM
mitchv10
Jul 25, 2007 12:35 AM
