front wheel bearing
Old Mar 25, 2010 | 11:46 AM
MMSGuthrie110's Avatar
MMSGuthrie110
front wheel bearing
i have my locking hubs removed. will it be okay to drive for a week or so with the wheel bearing exposed?
Old Mar 25, 2010 | 12:28 PM
Sgt Neutron's Avatar
Sgt Neutron
Even for just a week your wheel bearings will be exposed to water, dirt, road salt, sand, etc. all of which can kill a bearing quicker than snot. You can drive with it exposed, but may cause considerable headaches later.
Old Mar 25, 2010 | 12:38 PM
darthice's Avatar
darthice
it should be ok if you are going to change the wheel bearings after that week
Old Mar 25, 2010 | 01:00 PM
andym's Avatar
andym
I wouldn't do it. It's not that hard to put the hubs back in, is it?
Old Mar 25, 2010 | 04:17 PM
Iron bottom's Avatar
Iron bottom
Something you may try. Plumbing test caps. There is one known as a jiffy cap. It is made of rubber and slips over an open pipe to do a water test on the system. It is held on with a hose type clamp. These are pipe OD size, and I would say they will be about 2 1/2 and 3 1/2 inches. There are other larger and smaller sizes.Lowes or Home Depot usually carry them. They are not very expensive. I cannot quite picture exactly what your situation is, so just a suggestion that may help.
Old Mar 25, 2010 | 11:53 PM
zxwut?'s Avatar
zxwut?
Just pop the old ones back in for a week or so.
rellik74
1983 - 2012 Ranger & B-Series
Jan 16, 2012 04:12 PM
Delta
Oil & Lubrication
Apr 14, 2004 12:37 PM
Redn99
Sep 16, 2002 11:00 PM
kings51
Sep 11, 2002 12:03 PM
Scott250
Garage & Workshop
Aug 1, 2002 09:37 PM
