Edge Insight CTS3 vs FORScan for Real Time PID Monitoring?
@Sous, @FordTruckNoob, @Tpayne621 and @BWST et al.
What are the pro's con's comparison of Edge Insight vs FORScan for Real Time PID Monitoring?
I would likely permanently display FORScan on a dedicated screen of some sort.
Just like Edge Insight CTS3 is displayed on a dedicated screen.
@Tim Hodgson If a dedicated screen is what you’re after then the Android head unit is not it. How fancy does the graphics on the dedicated screen have to be? If dot matrix text will suffice then a Scangauge II does great. If you want fancy graphics on that dedicated screen then the CTS3 is pretty much it.
There are advantages and disadvantages to each of the options you have proposed above and only you know what will be right for you. Although, I will provide a few pros for FORScan (FSL) right off the top of my head.
1. You can use a BT adapter for as little as $22 for a BAFX. You can go up to an OBDLink MX+ for $100 or so if you feel the need.
2. You can use an old and outdated phone or tablet that runs iOS or Android.
3. FSL will read 100% of the codes for your van including PCM, VSM and 4R100 codes.
4. FSL has many diagnostic tests it can run in the event you need them.
5. FSL just works with minimal setup.
6. One time purchase for FSL of $5. I have FSL installed on 4 devices and paid $5. It is hosted on the FORScan website now, not Google Play.
7. You can have multiple "profiles" with different PID's you want to view at different times during testing or monitoring.
8. FSL samples data in 8ms sections.
9. You can use the PID Charting Tool created by BWST in seconds if you are trying to track down a problem.
10. FORScan has the ability to change a few things like tire size.
11. The data log is easily output into spreadsheet format viewed by programs like Excel or Open Office.
12. You can send data logs directly from FSL via email or if you are using an old mobile device you can transfer them via WiFi direct or BT.
13. There is a very robust community and forum over at the FORScan website.
14. You can use a wireless charger for the mobile device and remove the device from the vehicle easily if you choose.
15. The device can serve many purposes like navigation, audio streaming, etc... You can run FSL in the background and have navigation on the display and switch back and forth as you see fit.
I am sure I am forgetting a couple of things, but I think you get the idea.
One of the major downfalls is that you cannot read, view or log anything that the PCM, VSM or 4R100 is not capable of. Another is that the display is very basic with only a few color choices for the gauges and zero layout choices other than gauges, line format or graph format.
- There are, but PC FORScan is free unless you want "advanced" features that 99% of people don't want. FSL is a one time $5 purchase and has 90% of the features of regular FORScan.
- There are no subscription costs for either version of FORScan.
Take a look here: https://www.ford-trucks.com/forums/1...d-q-and-a.html
The following users liked this post:
Biggest downfall between both is you can't add a egt to the forscan or other gauges like fuel pressure coolant temp. But forscan does do cct and buzz tests which tbe cts3 does not. Honestly to me both are worth having forscan setup can for cheap. Think I got 20 bucks in the Bluetooth dongle and the app. I hardly ever use it. Maybe when I'm clearing a code on my ranger or want to read something on it. My on me 250 with the cts3 ive omly ever used the forscan for playing around trying out the cct and buzz test.
Could start off with forscan since it's cheap enough and see if you happy with that setup. If you already have something to use as a screen.
I prefer the cts3. It's dedicate. Always there. Boots up and is showing gauges about 5 seconds after you start it without connecting anything or pushing any buttons. Can add whatever gauges you want. Can even use it for a switch panel and turn on lights or other accessories. Does cost more then forscan obviously if you already have something to use as a screen.
ForScan gives the most indepth info.
I have the BT modules, and the USB Cable for a Windows laptop
I have the CTS-3 and you can change the PID you want to monitor while flying down the highway.
I changed Batt Volts on the 1st screen to ICP which I thought was more valuable.
I already have a DVM in the power port, it shows Volts
the CTS-3 has 3 screens, the last one is way too busy to use while driving
the 2nd screen isn't much good in stock form, it needs to be modified, just never messed with it
@Tpayne621 for the Win !
I want instant visual of dual EGTs, fuel pressure and transmission temp.
And I have New Generation STAR with the appropriate card for my vehicle for testing, so that can substitute for FORScan for now.
Thank you Brothers for all the advice and help!
If you want PCM and auxiliary data on one screen, your options are limited and you likely know what they are.
@Tim Hodgson , good luck with your project and we all hope you are happy with the end result.
