Quick engine bay identification
Old May 10, 2023 | 09:44 PM
kr98664's Avatar
kr98664
Originally Posted by CDewey
I have nothing on the dash or any controls that would indicate cruise control.
Did you check the turn signal lever? Some aftermarket systems had a controller that replaced the lever. If the lever looks stock, it may have been a version that clipped on. Any mystery wires on that side of the steering column?
Old May 11, 2023 | 06:43 AM
Max Capacity's Avatar
Max Capacity
one thing I noticed, your battery is backwards, This is what it should look like for the terminals.
Old May 11, 2023 | 08:40 AM
CDewey's Avatar
CDewey
4wd Low
Originally Posted by Rembrant
What is the one I have circled in red below? Is that a vacuum motor for a dealer or aftermarket cruise control? That's what it looks like, but they're not usually in that location, at least not that I have seen. Then again, none of my Bullnoses had cruise, factory or aftermarket...
It’s the old battery anyways, it’ll be replaced once the truck gets going! Thanks though!
Old May 11, 2023 | 10:13 AM
Max Capacity
When it comes time, it's ok to put in a higher capacity battery.
Old May 11, 2023 | 11:23 AM
kr98664's Avatar
kr98664
I noticed you're missing the handle for the jack. You won't realize it until stranded somewhere by the side of the road. It clips across the top of the radiator. Details here:
https://www.ford-trucks.com/forums/1...k-storage.html
You'll also need a battery hold down:
https://www.dennis-carpenter.com/tru...old-down-clamp
The J bolts are available separately from many sources.
Old May 11, 2023 | 10:09 PM
BigBlue2's Avatar
BigBlue2
Those J bolts magically disappear in about 10 years unless you coat them with about 2 cents worth of Fluid-Film which will make them last for a lifetime. Coat the battery pan too unless replacing those strikes your fancy.
Mortec.se
Mar 16, 2023 01:28 PM
cdcava
16
Aug 8, 2022 03:33 PM
Whitey5.0
Feb 10, 2022 06:36 PM
KrenzyRyan
62
Dec 20, 2013 10:04 PM
AmongHidden
May 6, 2012 07:55 PM
