Cab Ground
Old May 3, 2023 | 11:15 PM
RTT's Avatar
RTT
Red face Cab Ground
Is a ground wire needed to ground the cab to the frame if so what AWG
Old May 4, 2023 | 01:13 PM
kenny nunez's Avatar
kenny nunez
Cab ground
Use a #10 wire with the correct terminals frame to cab, you want the same from the engine to the cab. Also run another #10 to the radiator support from the battery. Strange things happen when things are not grounded together.
Old May 4, 2023 | 05:03 PM
1browski's Avatar
1browski
I grounded my cab from the top of the engine to the cab on my 72 f250 like it was factory on my 70 f250. I think I will add an extra for the heck of it from the frame to cab while I am making a ground to the bed.
Old May 4, 2023 | 09:52 PM
RTT's Avatar
RTT
Wink
This is exactly what I have read , but did not know 100% about the cab to frame !
I was already in the process of battery to radiator support with a #12 . I did almost twist 2 #12's together because I thought one #12 was slightly too small
There is actually a place on the firewall for an engine ground I have a #12 on it . I will change all to a #10 or bigger in the future
THANX.......
Wonder what 2 #12's equal to
Old May 4, 2023 | 09:59 PM
RTT's Avatar
RTT
Wink
I totally agree with Kenny cause I read about the exact 3 locations as he but did not know the size wire & if you actually needed a wire because the cab sits on the frame
I kinda figured the engineers would want an actual wire ........Now I must figure out where to put the wire..........
Thank-you both for the replies.....
Old May 5, 2023 | 09:56 AM
1964 Model's Avatar
1964 Model
I make my own out of old battery cables. Probably heavier than necessary, but it works.
Old May 5, 2023 | 03:05 PM
1browski's Avatar
1browski
My engine and battery grounds are made from leftover 1 gauge cable. My cab ground is 6 gauge leftovers.
Old May 15, 2023 | 02:39 PM
RTT's Avatar
RTT
I have done some commercial electrical work & was told you can never have too big a ground , one case where BIGGER is better !!! I started post to see what you guys thought was the minimum or factory specification !!! I just wanted a quick solution until I could find a correct or even bigger one !!!
I do think but far from certain that my brake lights & marker lights are brighter since I added the ground !!!
I have seen a ground strap actually , but think that may have been for a Chevrolet , maybe a Ford but it looked good but was $15.00 I think , probably more...........and even more since then since everything seems to have gone up in price..............!!!
garygnu
Large Truck
Jan 13, 2023 12:07 AM
JerryBills
Jun 16, 2015 06:33 PM
Jermafenser
23
Apr 5, 2007 03:52 PM
teederj2002
Aug 13, 2003 09:52 PM
Cdn Eh
Jul 19, 2003 06:01 PM
