1316 code - not uvch
Old Apr 29, 2023 | 02:18 PM
jgg123's Avatar
jgg123
What's up fellas, bit of disappointing news this morning. About a week ago I was driving to work and the truck started running rough, it almost felt like the front wheels were out of balance and it only happened at certain speeds (rpm)
Last year my passenger side uvch came loose and I was in a hurry so I just pushed the connector back in. I figured the uvch worked it's way loose and caused the miss/CEL.
Yesterday and today I changed glow plugs and uvch harnesses. Both sides were loose, passenger side almost off and I thought for sure that was the problem.
Started up the truck after and problem is still there. Could it be an injector? The truck had sat for months, I'm not sure if that would contribute to anything.
Just wondering what my next course of action should be. Buzz test?
Old Apr 29, 2023 | 02:32 PM
Kintla's Avatar
Kintla
Do you have any codes? Buzz test can't hurt, though I'd check for any codes and run a cylinder contribution test too. 8 usually doesn't pass on my truck, but when I had a nasty miss #3 failed too so I knew something was up with that injector.
Old Apr 29, 2023 | 03:00 PM
jgg123's Avatar
jgg123
Yeah I have a check engine light and a 1316 code.
The miss is minor but noticeable. Can I do damage by driving like this?
Old Apr 29, 2023 | 03:22 PM
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
Could be a solenoid acting up... Buzz test it and see what you find.
I don't have my documentation with me, so I am not able to identify P1316.
Old Apr 29, 2023 | 03:45 PM
Kintla's Avatar
Kintla
I guess you did have that info in the title...
1316 is an IDM code, not an expert on it but could be a short somewhere. I think if you run a buzz test it may give you more specific info on which cylinder is acting up.
Old Apr 29, 2023 | 04:00 PM
jgg123's Avatar
jgg123
QUO6]Do you have any codes? Buzz
​​​​​[/QUOTE]
Codes
Old Apr 29, 2023 | 04:29 PM
BWST's Avatar
BWST
Got Data?
Run the KOEO Injector Electrical Self test (buzz test) and see what it spits out. Should give you what injectors it's complaining about from that P1316 IDM code.
Old Apr 29, 2023 | 04:31 PM
Kintla's Avatar
Kintla
That's a good mess of codes. Are those all fresh? I'd delete them and pull again after running it to see which come back
Old Apr 29, 2023 | 06:15 PM
Dan V's Avatar
Dan V
P1316 is telling you to pull the IDM codes as I recall.
Old Apr 29, 2023 | 06:40 PM
jgg123's Avatar
jgg123
Guys, thanks for the input. I have company over right now I'll report back tomorrow.
Old Apr 30, 2023 | 12:08 PM
jgg123's Avatar
jgg123
Ok gents, I just ran the buzz test. results:
P1273 Cylinder No.3 Hight To Low Side open
This DTC may be caused by:
Open circuit
harness wiring
fuel injector
P1275 Cylinder no 5 high to low side open
Open circuit
harness wiring
fuel injector
So this sure seems to be a wiring issue on the passenger side? With the new uvch where do I begin?
Old Apr 30, 2023 | 03:59 PM
Kintla's Avatar
Kintla
You'll want to ohm out the uvch, the injectors themselves, and/or at the 42 pin to isolate the issue. It's been a bit since I've done this, I ended up having a mechanical failure not electrical with an injector so didn't see the process through to the end for electrical troubleshooting. Others with more experience will no doubt weigh in. Best of luck!
*These images are poached from a Tugly thread on this topic.
Old Apr 30, 2023 | 04:10 PM
Whitey Ford's Avatar
Whitey Ford
FTE-Spread The Knowledge
Sounds exactly to the word of a fuel issue we had. Could the codes be from a secondary issue involving the loose uvch?
Old Apr 30, 2023 | 04:15 PM
jgg123's Avatar
jgg123
fuel issue?
Old May 1, 2023 | 02:40 PM
jgg123's Avatar
jgg123
OK, ohmed out the passenger side UVCH. (something I should have done with the valve covers off but I digress....
Firewall
G1
G 2
I1
I2
C
I3
I4
G3
G4
Grille
I got an ohm reading of 3.8 ish between C and I1, C&I2, C&I4. I was not able to get any measurements between C and I3. Like as if it was an open circuit. Mind you this was after replacing the uvch harnesses already.
Sorry for asking to be spoon fed, but what should I be checking next? Should I order a replacement injector? Solenoid?
Thanks
