Auxito LED bulbs adjustment
Old Apr 29, 2023 | 10:20 AM
iConnect's Avatar
iConnect
Question for the people that installed the Auxito bulbs…
The bulbs must be installed North-South, with the frontmost led up. The problem I have found is that the main “collar” (the part common to halogen bulbs) does have three “prongs” but they don’t seem to be symmetrical and therefore it goes in only one way; then the led can be rotated but only about 170 degrees, not a full half turn. The practical result is that I can only have it about 10 degrees from vertical, which I’m sure is not ideal for the beam shape.
How did you solve this???
Old Apr 29, 2023 | 12:06 PM
longhaultransport's Avatar
longhaultransport
Not sure about that brand but BeamTech bulbs can be rotated in the collar. They use a set screw to hold them in the correct orientation.
Old May 1, 2023 | 07:47 AM
GNR22's Avatar
GNR22
I don't know how many different variations there are now, but there were 3 different auxito bulbs that fit these trucks back when they were giving them out here for review. The style that I had for review don't have any kind of angle adjustment, but they are straight up and down, or at least straight enough that I can't see an issue. They were ungodly bright though. On the road, in the ditch, in semi driver's eyes. Even if you got your bulbs straight, you're never going to get a great pattern, at least that's the experience that I had.
Old May 1, 2023 | 03:41 PM
Matt Pace's Avatar
Matt Pace
I get flashed all the freaking time but I haven’t done anything about it. I wasn’t sure if there’s anything to do about it or just replace them but it’s getting old getting flashed all this thing in time.
Old May 2, 2023 | 11:02 AM
longhaultransport
Aim them down?
Crazy idea, I know...
Old May 2, 2023 | 12:04 PM
Matt Pace's Avatar
Matt Pace
I’ll probably just deal with mine for now. Since getting old, I’m not driving at night very often. There have been a few flashes I got that were very well timed and I understand each time it happens but I did hear you can get a spacer to help with the aiming. I’m not sure what spacer or from who but I’ll look for it soon
Originally Posted by longhaultransport
Aim them down?
Old May 2, 2023 | 01:24 PM
iConnect's Avatar
iConnect
The first day I installed them I was getting flashed but then I realized that the bulb has to be in the right position or it will invert low and high beam. I had them upside down so I had the high beam out all the time...
To be correct you have to look at the two LED cells on each side, you will notice that one is more in front than the other. The one in front had to go up, and this is my problem, I don't seem to be able to have them "straight up" but just about ten degrees to the side...
Old May 2, 2023 | 02:28 PM
morehouse7's Avatar
morehouse7
There's a screw adjuster for the whole assembly, lube the gears in the adjuster before you try and move it they are only plastic and easily broken. One per side, front edge of the engine compartment under the hood. Park against a wall and move each side down the same amount.
Old May 2, 2023 | 03:48 PM
Matt Pace's Avatar
Matt Pace
is this on the pheasant trucks like mine that originally came with halogens? If so, awesome!
Old May 2, 2023 | 03:49 PM
Matt Pace's Avatar
Matt Pace
ah…….. interesting and thank you!
Old May 3, 2023 | 06:37 AM
Poncho450's Avatar
Poncho450
Aim them down?
On a 2017 that I bought new, when I went to adjust the headlights after installing Beamtech I discovered that the truck came off the dealer's lot with the headlights set at max height. Had to adjust them down quite a bit.
Old May 3, 2023 | 03:58 PM
Matt Pace's Avatar
Matt Pace
good stuff! Appreciate it! Hopefully I can quit blinding people
Old May 3, 2023 | 06:39 PM
StonedGrey's Avatar
StonedGrey
I found the solution.
Put the bulbs that the headlights were design for back in. Aim the lights properly. This way you can see without blinding the driver of the 4,000-9,000lb vehicle driving at you.
jimmm
2009 - 2014 F150
Feb 3, 2021 11:15 AM
Poncho450
Jan 12, 2021 05:59 AM
18SD_Lariat
Jan 11, 2019 10:39 AM
rangerbob406
Nov 14, 2015 12:56 PM
Downriver Thunder
Dec 6, 2006 03:08 PM
