2005 Psd
Old Nov 20, 2003 | 05:31 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
[i]I found out that starting in 05 SD's will only be available in CA with the Torqueshift due to emissions. Ford is also aware that the lower radiator hose can/will rub on the steering box and they recommended tying it off with wire ties in order to keep it away from the steering box until a change can be made.
[/B]
Is this fix needed on the Excursion also?
Old Nov 20, 2003 | 05:40 PM
jschira's Avatar
jschira
Yes. As far as I know. It is a problem with how the 6.0 fits in the engine bay.
Old Nov 20, 2003 | 06:19 PM
mattsf250's Avatar
mattsf250
i just found this info on the current 6.0.
The 6.0-liter Power Stroke® V-8 is a direct-injection, 32-valve turbodiesel with cast-iron block and cylinder heads. Featuring innovative Electronic Variable Response Turbocharging (EVRT), hydraulic rail fuel injection, pilot injection, and exhaust-gas recirculation, the 6.0-liter Power Stroke® boasts the highest torque and horsepower in its class.
Old Nov 20, 2003 | 07:58 PM
jschira's Avatar
jschira
OK. The Super-600 must use the same injectors as the current 6.0, which is not a common rail system.
They must call this "hydraulic rail".
Old Nov 20, 2003 | 08:44 PM
IB Tim's Avatar
IB Tim
Wonder if a note will come out on this, or is this how we find out!
Start to crawl around under it on Sat.
Old Nov 21, 2003 | 06:38 AM
jschira's Avatar
jschira
A wise precaution.
I had to fix a lot of rubbing connections on my 7.3, and they had been making that for 4 years!
basstardo
Nov 17, 2002 06:00 AM
NoMo
Apr 28, 2002 12:22 AM
powerstroker250
Mar 6, 2002 03:52 PM
ceferino
Jun 13, 2001 03:59 AM
alantbird
Jan 28, 2001 08:33 PM
