PSD "gushing"
Old Feb 14, 2001 | 11:28 PM
ceferino's Avatar
ceferino
PSD "gushing"
Old Apr 5, 2001 | 04:30 PM
mp's Avatar
mp
PSD "gushing"
Just picked up a 2000 Excursion Limited 4x4. My first diesel, awesome by the way, when it is started and idling after about 2 minutes I get a whooshing from the tail pipe. It sounds like extra pressure coming out of the exhaust. I read something about a "wastegate" and was wonding (bear in mind I know nothing about the diesel engine) if the "gate" was not sending this pressure to the engine since the engine did not need it while in idle? The truck just turned 33,000 miles. As a side note, I bought it via Ebay and paid $30,000 for it. I am told I got a steal. I have changed the fuel filter, air filter, oil and filter, and had the transmission flushed and serviced. I don't think any of these are related, just giving background.
Thanks in advance.
Old Apr 6, 2001 | 10:32 PM
ceferino's Avatar
ceferino
PSD "gushing"
Sounds like your cold weather exhaust restrictor valve in action. If it's less that 45 degrees this baby kicks in to help warm up the motor faster and keep it warm.
If you tap the brakes and the noise stops, that verifies that it's the exhaust restrictor.
fyi//Reno
00 xcrushn diesel, 4" procomp, safarigard, no-slip, etc
Old May 10, 2001 | 01:16 PM
bigfordman70's Avatar
bigfordman70
PSD "gushing"
yep, it's the Ehaust Backpressure Valve. (EBV)
BFM
Old Jun 13, 2001 | 03:59 AM
heds's Avatar
heds
PSD "gushing"
Smiles: The best to all**ED-RETIRED**
**REMEMBER FREEDOM IS NOT FREE**
Y2K X LTD. 2XWD - SS Grill Guard - Fiberglass running boards-Sunvisor +other goodies
**LIFER NRA-TEXAS STATE RIFLE ASSOC.& GOA MEMBER NRA\ILA**VOTE**
I would test or change the coolant. You can get some test strips at Ford, International and some parts houses. We have an additive in our diesels that keep the cavitation process from developing pin holes in our cylinder walls from forming. Th level you get on the strip should be in te range of 1.8 to 3.0. Too much is not good either as it is har on the pump seals and may perciptate out of solution to.
Take care and enjoy that bugger.
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
