I know this is backwards for trucks that are meant to pull. And I have never seen it, but seeing a car being flat towed behind an RV made me wonder if it's even an option for our Super Dutys.
A lot of variables to your question.
There is probably some guidelines in the owner's manual about towing a Super Duty.
Perhaps one of the tow truck drivers can chime in. Seems there is a mileage limit a vehicle can be towed. Something like 15 miles +/- then the drive shaft must be disconnected.
The problem is having the drive shaft spinning the gears in the transmission and not getting proper lubrication in the transmission.
A 4 wheel drive can have the front hubs locked out and that keeps that drive shaft from spinning.
Manual tranny in neutral might be ok. Transfer case in neutral might be ok (If that's still possible, i don't mess wIth 4WD). Another option is pull the axle shafts out of rear. Easily done, slightly messy, simple cover for the hole.
The concept of using a heavy Superduty as a run-a-round vehicle is not one I've ever imagined.
If doing it, I'd pull the axles out of the hubs so only the axle bearings would see wear. Plates could be made to replace the axles, or cut salvaged axles to a short stub to retain the o-ring. You can lift one side of the axle off the ground so the oil stays in the hub when removing that side, cap, then do the other side.
I understood that Jack. I just wanted to say that driving tight corners is not possible.
Apart from all the other technical things like brakes and trans lubrication, that would be reason enough for me not to do it with our Superduty trucks.
Isn't it the motion of the ring gear spinning that causes oil to flow down the axle shaft tubes to lube the wheel bearings??
Wouldn't doing as you suggested make it so the wheel bearings are no longer getting oil supplied to them and they'd therefore burn up after a little while?
All my training has had the full-floating hubs filled with oil after grease packing the bearings, and then oil exchange happens with slopes and cornering, oil flowing down the axle tube. I have difficulty visualizing how oil gets pumped from the differential when you have a long, round shaft spinning, centrifugally flinging oil off into a straight axle tube without directional vanes. The oil has to migrate up the slope of the swaged axle tube end. It will be on slopes and turns.
In something like Fleet Owner or Trucking magazine, a long, long time ago was a story, or paragraph within a story, about you can tell when a long-haul truck fleet repeatedly has driver's side hub bearing failures they do not have a good maintenance program. Differential lubricant levels were not checked—long highway straights with the normal slight angle to the right shoulders, high side starved.
