Leeds brake pressure switch-tight fit
I replaced the original master cylinder with a dual master cylinder-still running drums on all brakes.
https://leedbrakes.com/i-23439162-manual-dual-bowl-master-upgrade-kit.html
Brake lights are not functioning-diagnosed that the pressure brake switch needs to be replaced.
I have a new one to install, but the spot where the brake switch is located.
Is there a tool or tool mod to get in that tight a spot or do I need to remove the brake lines that are on either side of the switch.
Any hints or links that have addressed this is greatly appreciated.
This is the bottom view looking up.
This is the side view.
The following users liked this post:
I would try a cloth oil filter wrench. The kind with a cloth band. You can get to your switch from the bottom.
https://www.walmart.com/ip/BikeMaste...SellerId=16532
Just my .02 cents. If you know how a pressure brake light switch works, they do not come on until you are actually applying the brake. I like my Old Iron more than that so I always "switch" to a mechanical switch on the pedal when I get a chance. Most people drive like idiots already, we don't need to slow down their response time as well.
Best to pull and plug the pressure switch. They can leak. I also converted to a mechanical switch on the brake pedal (70's Ford pickup switch I believe). Popped out the rubber bumper on the pedal and put the switch there.
Adding a dual reservoir master and prop valve separates the front and rear brakes. If you blow a rear line or wheel cylinder, you’ll still have front brakes.
Because if you’re running the original one-line, jar type master cylinder and you blow a line or wheel cylinder then you will have zero brakes.
My question was if using a dual MC but keeping drum drum, do you actually need a proportioning valve?
Something like this should just bolt on. If you are shopping for one try to find one that comes with the boot and pedal rod.
BrakeBest Master Cylinder - Remanufactured 10-1386 | O'Reilly Auto Par (oreillyauto.com)
My rears will lock-up early without the proportioning valve, and I need to dial them down quite a bit to get balance. My truck is not 100% original with a front axle and brakes from a ’74, large wheels and tires, heavy engine, short bed - so my experience could be different from other’s.
NO. As long as you use the correct Ford master cyl. with residual pressure valves in both circuits. But you can use one if you want. The drum/drum dual master cyl. systems did have a differential pressure valve. But all that thing does is turn on a light in the dash to let you know you have a failure in one of the circuits.
thanks for the lead on the master cylinder from o’reilly, I didn’t no much more than I did now…still learning.
I bought the tool for the brake light switch. I measured it at 1”.
I found this but it’s a little too big-I thought 1” & 1-1/16” would fit a both sizes?
what does that actually mean?
I’ve never used anything like this before (obviously). Should I return it and get a socket that’s 1@ only?
Thanks in advance,
rtc
Success, for the moment-
I was able to locate a socket, locally, that would work.
New brake light switch installed-and they work. Next time around, I’m going to mount the electric switch.
there were a few leaks-they seem to have stopped after snugging down the lines and pumping the brakes.
I usually do a pre-flight before I take Grace out-for any drips or pieces falling off.
(I had the battery tray hold down clank to the ground 😬made one of those tool box empty-ing sounds I don’t like to hear before a cruise)
The socket I found (at one of those auto zone stores) had a 12 point center I don’t remember ever noticing before.
Another reason why got this ol’ girl…to learn.
thanks again for the info.
If you think of anything I missed-let me know. Always ready to learn some more.
rtcapo
rtcapo
willie71
06-23-2022 01:05 PM
Nobby
06-26-2021 01:17 PM
52F1Gary
12-04-2014 09:01 PM
