Big Block Ford I.D.
Old Apr 8, 2023 | 05:07 PM
dnpowers's Avatar
dnpowers
Trailering
Big Block Ford I.D.
Can anyone help me ID this block from these pictures?
dnpowers's Avatar
dnpowers
Trailering
Old Apr 8, 2023 | 07:11 PM
85e150's Avatar
85e150
An FE block, size unknown.
The "E17" mark should be 4 characters, such as "8E17".
"352" appears on all blocks up to a certain point after 1971.
It looks like someone put aluminum heads on it, so it could be reworked into something quite different than what it was originally.
Try the wire down the plug trick as described above in the FAQ.
Old Apr 8, 2023 | 08:35 PM
dnpowers's Avatar
dnpowers
Trailering
Am I missing another casting number somewhere? My friends father built this motor and passed away from a jeep rollover shortly after. I'm trying to help them i.d. some parts.
Old Apr 8, 2023 | 08:38 PM
dnpowers's Avatar
dnpowers
Trailering
I will use the dowel rod trick to check stroke also.
Old Apr 8, 2023 | 09:51 PM
SwampRattFord's Avatar
SwampRattFord
Stroke might be helpful but bore?
There are various tells but not without taking some stuff apart.
Old Apr 10, 2023 | 04:21 PM
stryder's Avatar
stryder
A closer look shows the date code as 2E17. Two dots making it 1972. May 17th 1972
Old Apr 10, 2023 | 08:10 PM
85e150's Avatar
85e150
I see it now---thanks!
In '72 it would be a 360 or 390 filled with sunken pistons. Clearly it's been reworked--how deep you'll only know if you pull it apart.
Old Apr 10, 2023 | 08:36 PM
cleatus12r's Avatar
cleatus12r
Butt-Head
If there's still any question ablut the displacement (360 or 390) and since the pan's off, just look at the rods. Also the back of the crankshaft.
Old Apr 30, 2023 | 08:08 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
360: 4.05" x 3.50" // 390: 4.05" x 3.78"
73 hi-boy 428 fe
Jun 3, 2020 12:44 PM
1browski
Jun 30, 2019 03:12 PM
Crash1975
Jul 26, 2016 11:34 PM
