E4OD Fluid Fill after Reinstall
Old Apr 6, 2023 | 10:13 AM
96150's Avatar
96150
Sorry for multiple replies, I just want to add that I have no issue pumping fluid out through the dipstick, I just need advice on whether I have properly filled it or if I have overfilled it.
Old Apr 6, 2023 | 03:35 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
I can't tell if you have too much, too little, or just right. If you'd answer the question if the engine was running when you checked the fluid I could answer your question.
Old Apr 7, 2023 | 10:57 PM
96150's Avatar
96150
The truck has been checked multiple times while running all saying that the fluid level is too high. HOWEVER, I have yet to put it in 1 or 2, and have only put it in P,R,D,N (although that shouldn't matter because 1 and 2 are just manual Drive, no?)
Old Apr 8, 2023 | 08:30 AM
Mark Kovalsky
No.
When in 2 you fill the intermediate band servo, the intermediate clutch, the coast clutch, and the passages leading to them. Moving to 1 actually doesn't fill any other clutch, so that one can be skipped.
Old Apr 8, 2023 | 09:16 AM
96150's Avatar
96150
That makes sense. Let me try that and see if it is still reading too high of a level. How long is it safe to run with overfilled fluid? Will a quick run around the block hurt? Also and had not mentioned this as I figure it did not matter but I have installed the TransGO E4OD HD-2 Tugger Kit on this transmission (Yes it was done correctly, I followed each step of the video carefully. I should also mention that before rebuilding the transmission, I had tried to simply drain the fluid (not a flush, so probably got abt 7 qts out) and then refill with 7 more qts (approx) and it also said it was WAY overfilled like now. Obviously since it was rebuilt (including new solenoid and everything) no residual fluid was left in and it went in dry (except for clutches and torque converter)
Edit: Quick run around the block and the fluid still appears way too high (picture coming)
Old Apr 8, 2023 | 01:41 PM
My4Fordtrucks's Avatar
My4Fordtrucks
Yup. That is way too much fluid for a cold transmission.
Old Apr 10, 2023 | 08:42 AM
96150's Avatar
96150
I apologize for wasting everyone's time. It turns out I had not properly secured the dipstick in both mounting spots upon reassembly. I had of course mounted it via the bellhousing bolt, but forgot to attach it via the stud and nut in the engine bay. I loosened the bellhousing bolt and pulled the dipstick over upon which I threaded the nut onto the stud in the engine bay, securing the dipstick tube in both spots. Finally, I retightened the bellhousing bolt. The angle of the disptick tube went from a roughly 70 degree angle (relative to the ground) to an 80 degree angle and thus the fluid level was correct and appeared at the proper line. Although I doubt anyone will make the same dumb mistake, I hope somebody will find this useful in the future. Thanks for all the help!
General Geoff
Apr 6, 2015 07:11 PM
mikeismadness
1978 - 1996 Big Bronco
Jun 1, 2011 06:57 PM
joewaldner
Jul 22, 2010 10:05 PM
cbeaur
Nov 26, 2003 06:08 PM
MIBPreacher
Oil & Lubrication
Jun 28, 2003 09:07 AM
