Under Dash Wiring
Old Mar 19, 2023 | 05:22 PM
Sandbox13's Avatar
Sandbox13
Trailering
Under Dash Wiring
I’ve been trying to track down some loose ends with the wiring under/behind my dash. Seems as though the previous owner hacked things up pretty good.
Does anyone know what the 3 connectors pictured are for? And if they should be connected to anything?
Old Mar 19, 2023 | 06:21 PM
tbear853's Avatar
tbear853
The wide black flat one with 4 wires, two red/blue and two black/red is where the column mounted NSS plugs in.
The wide yellow one with two wires, one red, sand a center unused hole is a switched power feed.
The two wire polarized black one with two yellow wires, I'm not sure that it's even Ford.
What year truck?
Old Mar 19, 2023 | 06:50 PM
77&79F250's Avatar
77&79F250
Moderator & parts slinger
X2 the yellow 3 hole is 12V keyed power and is used for OEM cruise control box.
Correct on the 4 flat wire one being the NSS.
The 2 round things with 3 wire L plugs are turning signal flasher and hazard lights flasher.
The 2 wire (1 male 1 female) is....ok heck what is that one again..thinking on it.
Old Mar 19, 2023 | 08:14 PM
tbear853's Avatar
tbear853
stumped you too. I meant to mention flashers, but fergot.
Old Mar 19, 2023 | 08:26 PM
77&79F250's Avatar
77&79F250
Yes stumped a little, that almost looks like a OEM door speaker wire connection.
Old Mar 20, 2023 | 02:17 PM
5851a's Avatar
5851a
Looks like green with red stripe for voltage regulator if equipped with warning lamps instead of gauges. Why 2 I don't know. Just guessing.
Old Mar 20, 2023 | 05:50 PM
Sandbox13's Avatar
Sandbox13
Trailering
Thanks for the help. I’ll try to see if I can find out where the 2 wire connector heads. Quite a mess under there.
I’m working on figuring out what’s going on with my tail lights, sounds like none of these would affect that.
Old Mar 21, 2023 | 05:35 AM
LandAndStone's Avatar
LandAndStone
Desk Jockey
Does any one have a picture of unadulterated wiring (perhaps as seen when peeking under the dash). Mines a bit of a mess and would like a view of the wiring (from floor POV) so I can clean it up. Currently working but resembles a bird nest.
Old Mar 21, 2023 | 10:00 AM
77&79F250's Avatar
77&79F250
I looked at a few parts trucks that have the instrument cluster out and I could NOT find that 2 wire (green/red trace) with the 1 male 1 female plug.
Old Mar 21, 2023 | 10:32 AM
alans77crew's Avatar
alans77crew
I am almost positive I have seen that before! I will go check some harness's I have and my factory diagrams!
Landman 454
Jun 10, 2022 09:37 AM
7.3_4Life
Jun 7, 2022 04:24 PM
Tina76
13
Oct 1, 2021 01:38 AM
beeser
Sep 30, 2013 06:28 PM
txfour
May 20, 2009 06:56 PM
