Help with EBPS
Old Mar 14, 2023 | 06:33 PM
Don Ruff's Avatar
Don Ruff
Originally Posted by Sous
Most likely a bad sensor, as your intuition seems to be telling you. Only purchase from a reputable seller like Bob at Diesel O Rings or Clay at Riffraff diesel. You mentioned the tube was clean earlier in the thread, so as long as you are sure it is clean and not clogged all the way though, the sensor, connector or wire are suspected inoperative.
99% of the time it is the EBP sensor.
Yes tube is clean., took it out cleaned it with a wire cable and a cordless drill, roto rutor effect, cleaned bottom side of sensor the depth of cleaning was the same as the length of ther external threads. After cleaning you can see the internal bottom of the sensor,. The tube connection at the exhaust manifold is clear as well, probed that with a pinch.
Will get a sensor in route from RIFF RAFF.
THANK YOU , will let you know the outcome.
Old Mar 14, 2023 | 08:09 PM
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
Coming back and closing the loop/thread once you have resolved the issue will be thanks enough to the FTE community. We have all been in your shoes and for most of us it has been a few times.
For what it is worth, I replaced my EBPS 50,000+ miles ago and it has been good since.
Old Mar 22, 2023 | 10:40 PM
Don Ruff's Avatar
Don Ruff
Replaced EBPS. Reads same as BARO, MAP with KOEO,.Start up it increases, did not go for a drive. Well see how it did on the way to work.
Thank you
rickdavis81
May 12, 2016 04:34 PM
6ohman2004
Jun 27, 2015 03:02 PM
johnblade
Jan 27, 2015 10:54 AM
firefighter23114
Apr 6, 2005 05:54 PM
Kevin
15
Apr 14, 2000 05:23 PM
