map sensor
Old May 11, 2016 | 08:15 PM
rickdavis81's Avatar
rickdavis81
map sensor
Finally got ae to connect to my truck. Retrieved codes p0606 and p0237. Checked voltage at the map sensor and had 5v reference and 5v on the signal wire with koeo. So I'm assuming my map sensor is bad. I've had some weird idle issues. Usually coming off the highway it'll idle like it has a miss but runs great. Would a map sensor cause this?
Old May 11, 2016 | 08:56 PM
fordpride's Avatar
fordpride
A map will just hurt performance
Old May 12, 2016 | 10:39 AM
rickdavis81
Well I thought the map was returning 5 volts. I unplugged it today and measured and I have 5 volts on the ref and sig wires. Pcm screwed?
Old May 12, 2016 | 03:44 PM
madpogue's Avatar
madpogue
What are you getting for BOOST and/or MAP on AE?
Old May 12, 2016 | 04:34 PM
rickdavis81
I couldn't keep it connected long enough to tell
brichert
May 26, 2017 06:46 AM
Capt.Schenk
23
Jan 19, 2017 08:19 AM
76250_4x4
Aug 12, 2010 10:09 PM
teamroper98
Jun 1, 2006 09:07 PM
oldhampete
Oct 28, 2003 10:24 PM
