Ebp sensor
Old Jan 25, 2015 | 12:44 PM
johnblade's Avatar
johnblade
Ebp sensor
I put the gauges in for map ,baro,and ebp. At key on they were all around 14 p.s.i . At idle the ebp went up to 20 and map and baro stayed close to 14. I took the sensor off and cleaned the tube no change. Is there any way to check this sensor with a electrical meter, I replaced one about a year ago and this time there didn't seem to be much for soot in the tube. Any ideas?
Old Jan 25, 2015 | 01:02 PM
bismic's Avatar
bismic
What rpm's did you have at the idle conditions?
Old Jan 25, 2015 | 01:15 PM
johnblade's Avatar
johnblade
I believe it was around 600 rmp at idle and it went up to around 22 at 2000 rpm
Old Jan 25, 2015 | 01:20 PM
bismic's Avatar
bismic
Seems a little high. Still have the cat?
Old Jan 25, 2015 | 01:26 PM
johnblade's Avatar
johnblade
Yes it's all stock.
Old Jan 25, 2015 | 09:12 PM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
Are you sure the vanes aren't stuck at 85%?
Josh
Old Jan 25, 2015 | 10:41 PM
fordf150guy's Avatar
fordf150guy
Just curious what you guys would say a normal ebp reading would be?
Old Jan 25, 2015 | 10:44 PM
Bullitt390's Avatar
Bullitt390
Should be less than 16 psi at idle.
Josh
Old Jan 26, 2015 | 04:43 AM
bismic's Avatar
bismic
Several possibilities
1. Bad sensor. Doesn't seem to be the case since it isn't that old and reads OK w/ KOEO. Never know though. There are electrical tests in the WSM IIRC. Maybe someone can track them down for you.
2. Gauge system isn't reading it correctly. Again, doesn't seem likely w/ KOEO reading being good, but again "Who knows".
3. Plugged tube. You said you addressed this though. DId you run anything down the tube to make sure it was open?
4. Stuck turbo. Doesn't sound like this is your issue since you didn't report any engine operating or starting issues, but it is possible as mentioned above. Have you experienced any such issues?
5. Plugging CAT. You can test this by running it w/ the downpipe disconnected. Do you see much smoke? Recently had injector issues? Run any bad fuel lately? A Plugged cat will cause low power issues.
What gauge system are you using?
Old Jan 26, 2015 | 06:23 AM
Bullitt390's Avatar
Bullitt390
Test for plugged Cat observing the APP Voltage compared to MAF voltage during acceleration.
Josh
Old Jan 26, 2015 | 08:05 AM
johnblade's Avatar
johnblade
Thanks for the responses, I will have to dig into this some more.It might be time to look into the turbo.
Old Jan 26, 2015 | 08:14 AM
johnblade's Avatar
johnblade
Scangauge,I think the Vgt was around 63%,when I was revving it in the driveway. I'll check that again.
Old Jan 26, 2015 | 08:28 PM
firedaniel's Avatar
firedaniel
Im interested in what you find I have the exact same numbers you posted. Curious what you find. Good luck FYI mine doesnt have a Cat
Old Jan 27, 2015 | 10:54 AM
RideDiesel88's Avatar
RideDiesel88
Everything after the exhaust port in the head causes back pressure. I would disconnect everything after your down pipe (muff and cat) and see if psi changes. Way easier than tearin into your turbo
Jmoen7
Aug 25, 2015 09:47 PM
hedhntr
Nov 26, 2012 10:06 PM
Ford79
29
Mar 5, 2009 12:34 PM
getnbz
Nov 8, 2007 09:27 AM
03_PSD
Oct 11, 2007 08:38 AM
