Transmission Removal
Old Mar 10, 2023 | 08:58 PM
canderson1015's Avatar
canderson1015
4wd Low
I’m trying to remove my t18 out of my 72 f250 and I can’t figure out how to disconnect all of the clutch linkage. Any tips?
Old Mar 11, 2023 | 12:44 AM
1browski's Avatar
1browski
To remove the T18 you shouldnt have to touch the clutch. Remove the drive shaft, backup light, speedometer, stick shift, removable hump(floor), 4 bolts, cross member bolts and the two bolts from the trans mount. Lift the tranny with a tranny jack(preferably), pull out the cross member, slide it back and lower it out. When I pulled mine from my 72 f250, I just reached in the cab with my engine hoist and stapped to it. I then disconnected everything except the stick shift and lowered it down onto a dolly and rolled it out. The engine was already out so I didnt have to seperate the two though.
Old Mar 11, 2023 | 08:17 AM
FuzzFace2's Avatar
FuzzFace2
The only time you have to mess with the linkage is if you have to pull the bell housing to replace the clutch.
I dont know what motor or how your linkage is but my 81 with a 300 six the Zbar is on the frame and to the block pivot so you just have to shorten the adjuster from the clutch fork to the Zbar and leave the rest where it is.
I think the 80's v8's the motor side pivot is bolted to the bell housing with a bracket.
Shorten the adjuster from the clutch fork to the Zbar, unbolt the bracket from bell housing and leave the rest where it is.
You should then be able to remove the bell housing and get to the clutch assy.
I cant see your year truck being much different.
Dave ----
Old Mar 11, 2023 | 04:55 PM
lilorbie's Avatar
lilorbie
Call Tony Angelo.
Scrub
Jul 19, 2017 06:28 AM
jsmahan
Jun 9, 2008 08:02 PM
tcbofade
May 21, 2008 08:47 AM
ruggles
Nov 11, 2007 12:07 PM
Katmandu
Aug 3, 2004 06:52 PM
