'50 headlight switch removal
Old Mar 8, 2023 | 07:50 PM
ct50f1's Avatar
ct50f1
I'm trying to replace my headlight switch. The shop manual says you push in a spring-release button on the switch and then remove the **** and shaft.
With the switch installed in the dash I'm having a hard time finding the "button". Does anyone have a picture of the switch that's not installed so I can see where the button is located? Thanks,
Old Mar 8, 2023 | 08:15 PM
abe's Avatar
abe
Here's a 53-55 switch. See the button.
Old Mar 8, 2023 | 08:24 PM
abe's Avatar
abe
This a 48-52 switch. Looks like the button is on the bottom.
Old Mar 8, 2023 | 08:25 PM
52 USCG Panel's Avatar
52 USCG Panel
Hi Dan. My "spare" switch is supposed to be for a 52:
The spring loaded button is on the left. It would be orientated toward the floor of the cab with the switch installed. Depressing the button allows you to remove the ****. With the **** removed, you can unscrew the bezel that holds the switch in place.
Good luck. As you are working on your truck, you must still have it. Did you have a change of heart about selling it, or are your just doing some repairs before putting it on the market?
Jim
Old Mar 8, 2023 | 08:33 PM
ct50f1's Avatar
ct50f1
Thanks, Abe. I don't think the switch I have looks like either of them. This is the best picture I could get of it.
Old Mar 8, 2023 | 08:43 PM
ct50f1's Avatar
ct50f1
Originally Posted by 52 USCG Panel
Hi Dan. My "spare" switch is supposed to be a 52:
The spring loaded button is on the left. It would be orientated toward the floor of the cab with the switch installed. Depressing the button allows you to remove the ****. The the **** removed, you can unscrew the bezel which hold the switch in place.
Jim
Jim, that looks a bit like what I've got (see response to Abe above) but there's no button on the bottom of mine. I'm thinking maybe the switch I have is from a '49 F-1 and I need to find the slot to insert a screwdriver.
I'm getting the truck ready to list on Hemmings Auction. The light switch works intermittently. The headlights didn't work when I took the truck out this afternoon but after I parked it and pulled out the switch the lights went on. I went to show my wife that they were working again and they wouldn't go on. I ordered a new switch from Carpenter tonight.
Old Mar 8, 2023 | 09:00 PM
52 USCG Panel
Sorry I couldn't be more helpful. Your switch is definitely different. When the replacement switch comes, hopefully you'll see how it works. Good luck with the sale. You'll probably be out and about driving your Model A soon.
Jim
Old Mar 8, 2023 | 09:04 PM
abe's Avatar
abe
Feel for it on the top.
Old Mar 8, 2023 | 09:07 PM
FortyNiner's Avatar
FortyNiner
The 48-50 switch doesn't have a button. Instead, there is a slot on the underside that is aligned with the slot in the lip in the dash. Your picture clearly shows the feature.
The **** shaft is held by a flat spring on the switch body that is keyed to the shaft.
With the switch **** in the off position, use a flat blade screwdriver inserted in the slot to push up and toward the firewall. While doing this, twist the **** and it will release.
Old Mar 9, 2023 | 08:43 PM
ct50f1's Avatar
ct50f1
Thanks, I'll give it a try .
Old Mar 10, 2023 | 03:59 PM
ct50f1's Avatar
ct50f1
Thanks guys for all the responses. Like FortyNiner said, you have to compress a spring by pressing it toward the firewall with a screw driver. That is, once you find it. It's hard to get a flashlight to shine where you need it to see the spring. Anyway, I got the shaft out and unscrewed the nut holding the switch to the dash. I haven't disconnected the wires yet because I want to have the new switch in hand so I can move one wire at a time.
For future reference in case someone's searching this thread, here's what the '49 - '50 switch looks like without any button.
The spring that holds the shaft:
The bottom of the switch - the thing that looks like a button is the rivet holding the spring to the case;
The top with the wiring attached:
Old Mar 10, 2023 | 04:13 PM
abe's Avatar
abe
Thanks Dan. I'm glad Ford improved it for 53-56 trucks.
Old Apr 12, 2023 | 01:32 PM
Eastfarthing's Avatar
Eastfarthing
4th Gear
Thanks, these pics are a life saver. I have been almost pulling my hair out trying to figure this out.
hooler1
Mar 26, 2018 05:57 PM
Bird-Dog 250
Sep 13, 2015 12:11 PM
Oldbike99
Aug 29, 2013 04:54 PM
gary678
Electrical Systems/Wiring
Aug 30, 2006 08:30 PM
jeffh
Nov 22, 2001 08:08 AM
