Picture explaining how to remove headlight switch stem?
Old Aug 28, 2013 | 04:16 PM
Oldbike99's Avatar
Oldbike99
I wonder if anyone has a picture to show me how to remove the headlight switch stem on a 1949 F1? Thank you in advance
Old Aug 28, 2013 | 04:43 PM
ZOOT's Avatar
ZOOT
Don't have a photo of it, but as I remember, push the small button on the bottom of the switch while pulling on the stem. I'm sure someone will correct me if I'm wrong.
Old Aug 28, 2013 | 06:29 PM
Oldbike99's Avatar
Oldbike99
I am familiar with the later Fords that used a spring-loaded button to release it, but can not feel anything like that on this switch. I am too old to get up under that dash to see very well!
Old Aug 28, 2013 | 08:47 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
7RA-11654 .. Headlamp Switch / 1948/50 all trucks & 1949 Ford Passenger Cars.
Left upper: 1949 Ford car dash pic. I don't see a button on the 11654 switch.
Old Aug 28, 2013 | 10:15 PM
51PanelMan's Avatar
51PanelMan
I just removed the headlight switch from a 52. It had a push button on the rear right side. If yours doesn't, then look for a small hole to stick a small punch through to release the stem.
Old Aug 29, 2013 | 12:27 AM
aussiecowboy's Avatar
aussiecowboy
Here you go champ!
https://www.ford-trucks.com/forums/6...al-1949-a.html
Old Aug 29, 2013 | 10:44 AM
NumberDummy
1951/54 uses the same switch (FAA-11654-A), but it's not the same as the 1948/50 switch (7RA-11654).
1949 Ford Passenger Cars use the same 7RA-11654 switch as 1948/50 trucks. Post 4 upper pic: There's the little charmer.
Old Aug 29, 2013 | 02:02 PM
FortyNiner's Avatar
FortyNiner
The key is to keep the stem pushed in while using a small screwdriver to release the spring through the slot on the bottom of the unit. It about jumps apart when done correctly.
Old Aug 29, 2013 | 04:54 PM
Oldbike99's Avatar
Oldbike99
Originally Posted by aussiecowboy
This was exactly what I needed. Thank you. I had researched all the info I could find to no avail.
Bird-Dog 250
Sep 13, 2015 12:11 PM
EastTexasTruck
18
Feb 24, 2009 12:11 AM
gary678
Electrical Systems/Wiring
Aug 30, 2006 08:30 PM
Tank
Jun 21, 2004 12:47 PM
frigerator
Apr 10, 2004 07:51 AM
