do clutch splines get grease?
Old Apr 12, 2023 | 11:27 AM
AllenV's Avatar
AllenV
Putting a new clutch between my Y-block and T98 transmission. The 1955 and 1959 carefully avoid mentioning grease on the splines of the clutch disc and transmission input shaft. The Duralast generic installation instruction talk about a small amount of spline grease from the provided packet. But no packet was in the box.
What is correct here? No grease? grease?
Thanks
Old Apr 12, 2023 | 12:56 PM
HT32BSX115's Avatar
HT32BSX115
Howdy,
My 57 Ford and 1954-55 truck manuals don't mention greasing the input shaft or clutch hub splines (at least I couldn't find it)
But a little look around the internet put me to a ZF site that indicates you should.
https://aftermarket.zf.com/us/en/sac...he-hub-spline/
I would grease it. But use VERY little grease to do it. Centrifugal forces are significant and any excess grease in there WILL end up on the clutch plate material.
I have mercruiser Out Drive spline grease, but any good wheel bearing grease is probably ok. a thin coating is fine. NO GLOBS.....
Cheers,
Rick
Old Apr 12, 2023 | 01:00 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Agree with Rick. Very little needed, I use just enough to prevent rust. The disc hub really doesn't move a great deal.
Old Apr 12, 2023 | 01:26 PM
HT32BSX115's Avatar
HT32BSX115
Here's another article that says it better than I can....and describes why one should grease the splines!
https://cvwmagazine.co.uk/best-pract...line-greasing/
Old Apr 12, 2023 | 01:42 PM
hobohilton's Avatar
hobohilton
My personal preference is to very lightly grease. Rust inhibitor, lube for disc to move on splines during operation and helps when stabbing the nose into the disc and bearing / bushing in the flywheel.
Old Apr 12, 2023 | 02:08 PM
AllenV's Avatar
AllenV
Thanks all. Greasing fits with my inclination as well. I was just surprised that both manuals don't mention it while going into detail on lubrication of the pilot bearing/bushing and, on bigger trucks, dabbing a bit of grease inside the pressure plate assembly where it takes the rotational load. I have a high-temp clingy grease in-stock that will do the job well.
By the way, if one polls the internet-at-large on this topic, all sorts of crazy practices pop up.
AllenV
Apr 10, 2023 10:05 PM
Prionus
Jul 28, 2021 02:17 AM
HIO Silver
Nov 5, 2013 05:08 PM
greyghost85
Apr 13, 2010 08:19 PM
lerry
Jun 24, 2003 10:31 AM
