Not starting.
Old Mar 7, 2023 | 10:24 PM
TyOwens21's Avatar
TyOwens21
1st Gear
Not starting.
I was only getting one click from the starter solenoid. I changed starter solenoid and battery and starter . I’m not sure what is going on but ever since I changed out all of those parts when I try to start the truck it kills the battery. I have to just disconnect negative terminal and reattach then the truck has power again
Old Mar 7, 2023 | 11:09 PM
Prototypemech's Avatar
Prototypemech
The need to fiddle with the battery cables is a sure sign of a bad connection between the battery and the cable. Do you have those 'repair' battery terminals on your cables? Those leave people stranded. You may also try to clean up your battery terminals and cables with a brush. As for your 'single click' problem, that is usually because of a faulty cable between the starter solenoid and the starter OR a ground cable between the engine block and the battery.
Old Mar 11, 2023 | 11:04 AM
Noboxstudio's Avatar
Noboxstudio
1st Gear
I had the same thing and just fixed it with heavy duty terminals now it cranks like crazy but still not starting
Old Mar 11, 2023 | 12:24 PM
Prototypemech
If you need help, please start your own thread and we'll reply to your problem on your thread.
JRT812
Mar 30, 2020 10:12 PM
osb
1978 - 1996 Big Bronco
Apr 11, 2011 08:15 PM
LSJUNIPER
Nov 22, 2010 11:39 AM
dracip
Jan 28, 2008 06:43 PM
PAUL_2
Jul 31, 1999 09:33 PM
