Truck will not start
Old Aug 26, 2008 | 06:18 PM
LSJUNIPER's Avatar
LSJUNIPER
My truck is a 1956 ford. It has a 1977 LTD motor in it (302).I have a new battery, selinoid and starter. I also replaced the battery cables. When I turn the key the selinoid clicks and the starter does not ingage. Not sure what the prob is......any help will be appreciated.
Thanks
Old Aug 26, 2008 | 06:32 PM
53OlderThanMe's Avatar
53OlderThanMe
Sounds like low battery, have you tried jumping it. If jumping doesn't work starter would be my next guess. Can you take the starter and battery into a local auto parts store for testing?
Ooops guess I should read your post more thoroughly. Sorry looks like you tried my suggestions.
Old Aug 26, 2008 | 06:44 PM
yield2s's Avatar
yield2s
start with the switch first.
by-pass it on the main terminals of the switch with a piece of metal, It will arc heavily so be careful!!!! If the starter kicks-in at that point then the contacts in your starter solenoid are shot. Cheap and ez fix. If nothin happens, It's either your battery or starter. At that point tap the starter while or before you try to start it.
Old Aug 26, 2008 | 07:23 PM
gdgerland's Avatar
gdgerland
First off, welcome to FTE. You have come to the right place for information. Glad to have you on board. You didn't say if you replaced all the parts to correct an existing problem or if this is a first time start up. It sound to me like you have a bad connection somewhere, either power or ground. The clicking of the solenoid does not mean that it is making internal contact. As mentioned above, jumping the solenoid will tell you if it is bad. If you are sure your battery is fully charged and when you jump the solinoid nothing happens, then my guess would be the starter. Not completely unusual to get a bad part now days. Also there could be a bad connection on the new battery cables. Re check all connections and make sure all connecting points are clean and tight. That being accomplished and still no luck, I would pull the starter and take it to be tested. Hope this helps, keep us posted on your progress.
Gil
Old Aug 26, 2008 | 08:14 PM
Old F1's Avatar
Old F1
My cyber space long distance guess is that the battery is not fully charged or a poor connection.
“but being wrong keeps me humble”
Old Aug 26, 2008 | 11:48 PM
Julies Cool F1's Avatar
Julies Cool F1
Yes to all of the above - including the welcome!
Check all the connections on the battery, the starter, on the solenoid, and also be sure to check that the ground cable is secure to the frame AND you have a good solid connection on both ends of the ground strap running between engine and frame.
But, this sounds like a shorted or dead battery.
Good luck!
Julie!!!
Old Aug 27, 2008 | 12:40 AM
Fomoko1's Avatar
Fomoko1
Welcome LSJUNIPER, great to have you on board!
Hope you get this problem licked soon.
Be sure to fill in the location field in your profile (from in your control panel) to let us know where your from.
Old Aug 27, 2008 | 07:46 AM
LSJUNIPER's Avatar
LSJUNIPER
Thanks for all of your suggestions!! And thank for the welcome... I will be working on the truck this Thursday and I will keep you posted on my progress.
Tanks again!!!!
Old Aug 27, 2008 | 07:47 AM
LSJUNIPER's Avatar
LSJUNIPER
Will Do!!!!!!
Old Nov 22, 2010 | 11:21 AM
LSJUNIPER's Avatar
LSJUNIPER
Been a long time since I checked this post out, my bad, I did get the truck running. I put a new battery in but it still didn't want to start. I think I forgot to mention I didn't start the truck for 5 years or so (building a garage). Anyway, once the new battery was installed I sprayed some mystery oil on the pistons and let it sit for a few days, then gave it another try..the motor turned but only for a partial amount each time I turned the key...after about 5 or so tries the motor became free and it actually fired and ran. Once the oil burned through it ran really well once again. One thing happened I thought was interesting is once the truck started a Chipmunk blew out on the exhaust!!! HAHAAH
Old Nov 22, 2010 | 11:39 AM
Julies Cool F1
Ah the missing fact!
BRay09
31
Jun 21, 2011 12:14 PM
Hennepin451
24
Oct 19, 2005 05:55 PM
happycat45
Jan 21, 2005 07:27 PM
The Tree
1978 - 1996 Big Bronco
Nov 30, 2004 08:51 PM
skipy
Aug 24, 2003 08:31 PM
