Starting issues
Old Mar 29, 2020 | 06:21 PM
JRT812's Avatar
JRT812
Starting issues
78 f150 400. Ran fine under normal circumstances. Went to start it yesterday and the starter just “cluncks” changed starters thinking it may be the issue and the one from the parts store does the same. Looking for some direction on what it could be.
thanks in advance!
Old Mar 29, 2020 | 06:34 PM
440 sixpack's Avatar
440 sixpack
Are you sure it's the starter clunking or could it be the solenoid ?
Check all connections good on the battery, solenoid and the ground battery cable ay the block. .
your battery could be toast also.
Old Mar 29, 2020 | 06:45 PM
JRT812's Avatar
JRT812
Im no mechanic but the sounds seems like it’s from the starter. The battery was tested and is good. Also the cables appear to be fine as well. I will look into the starter solenoid and appreciate the direction
Old Mar 29, 2020 | 06:55 PM
440 sixpack
If the starter is actually kicking in it's probably not the solenoid but it could be the connections on it.
Very often a condition like you're discribing is a bad battery connection. it will make contact but when you put a load on it it breaks down and won't turn the starter.
Old Mar 29, 2020 | 10:07 PM
83sd's Avatar
83sd
You need to determine if its the solenoid clunking or the starter. Another check you could do is see if you can rotate the motor with a breaker bar on the crank. My cousin chased a " starter issue" for a few days until I found cylinder 4 was full of coolant.
Old Mar 30, 2020 | 08:09 AM
JRT812's Avatar
JRT812
Thanks to everyone for the direction!
Old Mar 30, 2020 | 09:45 PM
JRT812's Avatar
JRT812
Update - not good outcomes. Changed some parts and noticed a bulge in the valve cover. Also, checked the coolant and it seems empty. Not looking great
Old Mar 30, 2020 | 10:12 PM
440 sixpack
Water in the oil ?
max burroughs
1978 - 1996 Big Bronco
Nov 2, 2014 04:33 PM
eramone1
1997 - 2003 F150
Feb 4, 2014 05:26 AM
2hole
Jan 18, 2012 02:23 PM
wallranch1
Feb 22, 2011 04:35 AM
CRUNKED77FORD
Oct 26, 2010 07:24 AM
