Working on a chevy!!?? 🤮
Old Mar 5, 2023 | 08:19 PM
Hyakkimaru's Avatar
Hyakkimaru
The answer when it comes to fixing a Chevy is scrapyard. Always scrapyard.
Unless it's a Corvette, which is likely to crash before it breaks down (aside from C8 Z06s apparently). In which case the answer is also scrapyard.
Exactly! I told him he should have bought a ford. I told him the problem is the bow tie on the grill
Old Mar 5, 2023 | 08:20 PM
Hyakkimaru's Avatar
Hyakkimaru
Originally Posted by knottyrope
He made a ball block Chevy
Old Mar 6, 2023 | 03:24 PM
Hyakkimaru's Avatar
Hyakkimaru
Well, I didn't make this thread for help but, does this look like a crack in the head? Doesn't seem so to me. What can we use to polish or find the Crack with?
Old Mar 6, 2023 | 03:41 PM
FordTruckNoob's Avatar
FordTruckNoob
Send it for magnafluxing?
Old Mar 6, 2023 | 05:58 PM
ToolmakerRob's Avatar
ToolmakerRob
Magnafluxing or you could see your future weld boss and see if they have a spray on weld check kit. It is basically a dye/penetrant and contrast color.
Rob
Old Mar 6, 2023 | 08:18 PM
udsuth78's Avatar
udsuth78
Just because they test ok for cracks doesn't mean they are flat. Heat is pretty good at moving metal, especially aluminum. The heads and deck need to be checked for flatness with a precision straight edge and feeler gauges at a minimum. What kind of head gaskets does it take? Some can be very particular about the surface finish too.
Old Mar 9, 2023 | 11:55 AM
KubotaOrange76's Avatar
KubotaOrange76
Its Comin Right for us!
Does it have a 3/4 cam?
Old Mar 9, 2023 | 08:19 PM
Hyakkimaru's Avatar
Hyakkimaru
I have no clue. It was a used truck that had been modified for more hp and speed. Pretty spuffy truck. I will have to get back to you on that. My brother doesn't have a phone and I don't live super close to him. I'll probably end up seeing him in the next couple days.
Old Mar 10, 2023 | 07:11 AM
Tpayne621's Avatar
Tpayne621
😂 Stop that
yhc
Aug 9, 2020 06:28 PM
GuitarJesus
Sep 22, 2014 11:56 AM
MK75Gunner
Oct 13, 2012 03:55 PM
mabc926
Sep 16, 2010 09:48 PM
1990Mustang
Aug 19, 2010 11:10 AM
