Sponsored by: Real Truck
Oil in the
Old Aug 18, 2010 | 10:54 PM
1990Mustang's Avatar
1990Mustang
Exclamation Oil in the
Hi,I am interested in buying this F-250 from a guy in Jersey.It has an issue
When you look into the radiator, you will see oil mixed with antifreeze. There's nothing else that seems to be wrong. They say; if the head is cracked or anything else wrong with the engine, there will be water-antifreeze in the engine too, in this case, oil is very clean and no antifreeze is mixing back.Could it be the oil cooler line inside the radiator that's leaking oil. Radiator,Heads?Etc
Thank You in advanced!!!
Old Aug 18, 2010 | 11:33 PM
brickie's Avatar
brickie
It needs a oil cooler new hoses and a lot of flushing,the EGR cooler might not be doing so well with a dead oil cooler.Don't drive the truck as oil in the coolant runes the cooling capability of the coolant.
Old Aug 18, 2010 | 11:36 PM
1990Mustang
Yeah i have owned many fords but for the year and the price it cough my att.is this a common problem?Thanx
Old Aug 18, 2010 | 11:44 PM
brickie's Avatar
brickie
The 6.0 is known to have casting sand in the cooling system leftover from production of the block,a coolant filter sorts that issue.The coolant cools the oil cooler when it overheats the oil cooler and or the EGR cooler fail.Some trucks are worse than others.
Old Aug 18, 2010 | 11:45 PM
1990Mustang
its a 1994 f-250 7.3 turbo.what does this normally cost?
Old Aug 19, 2010 | 12:06 AM
brickie's Avatar
brickie
Sorry I thought I was in the 6.0 section.Not sure about the oil cooler on the 7.3.Post in this forum it is the newer 7.3s but there are lots guys that I am sure will get you all the right answers.1999 - 2003 7.3L Power Stroke Diesel - Ford Truck Enthusiasts Forums
Old Aug 19, 2010 | 08:03 AM
Fishin76's Avatar
Fishin76
Nope, he need to be in the IDI section. That motor is a 7.3L IDI Turbo.
Pre-Power Stroke Diesel (7.3L IDI & 6.9L) - Ford Truck Enthusiasts Forums
Old Aug 19, 2010 | 11:10 AM
rbaker6336's Avatar
rbaker6336
It could need injector cups
the_auto_tech
Feb 2, 2015 10:27 AM
photomac
Nov 21, 2007 02:15 PM
ultimatereality5
Jul 3, 2007 12:36 AM
searchingforpowe
Modular V10 (6.8l)
24
Jul 6, 2005 09:16 PM
swirk
May 3, 2003 08:31 AM
