O2 sensor question
Old Nov 15, 2003 | 08:17 PM
MunsterGarage's Avatar
MunsterGarage
O2 sensor question
When an 02 sensor is failing, what are some of the things to expect?
Old Nov 16, 2003 | 06:44 PM
1987rangerpu's Avatar
1987rangerpu
the o2 sensor in my 87' ranger was gone and when replaced it got better mileage and almost actually passed the Ma emissions test.
Old Nov 16, 2003 | 06:55 PM
1ruralmailman's Avatar
1ruralmailman
usually 5-7 mpg of mileage goes away over night,strangely enough the seem to run a little smoother .ithink this has to do with the computer going full rich to keep you from melting down.
Old Nov 18, 2003 | 03:09 PM
gatesj's Avatar
gatesj
Even a marginal sensor will make the mixture richer. When they're working normally, they show low (0-0.5v) voltage for lean running and higher (.5-1v) voltage for rich running. When they start to fail they make less voltage and the computer thinks the engine's running too lean, so it enriches a little to compensate.
Old Nov 19, 2003 | 05:39 AM
Supercab's Avatar
Supercab
Cool
Could an O2 sensor thats going bad cause the computer to make the engine run so rich that it will act flooded upon a warm re-start? I think thats what might be causing my hard starting trouble.
Old Nov 19, 2003 | 07:27 AM
gasman6674's Avatar
gasman6674
I had a bad distributor cap cause that problem. I thought my injectors were dirty and leaking. I started fine in a cold start but acted like it was flooded when warm
Its a 92 302 BTW
Old Nov 19, 2003 | 08:39 AM
m14dan's Avatar
m14dan
The o2 sensor is out of the loop when you are starting so I doubt it could cause that. On mine especialy since it only has 1 o2 sensor I treat it as part of a tune up. It gets replaced every 60,000 along with the cap, rotor, plugs and wires. I don't take any chances with parts failing so I do it by the book. Also use only ford parts with a very few exceptions. The oxygen sensor is made by bosche wich you can get at autozone a lot cheaper.
Chistoso
22
Sep 18, 2009 10:13 PM
myst
Jan 26, 2003 11:53 AM
sternal2000
Oct 6, 2002 06:57 PM
georgedavila
1978 - 1996 Big Bronco
Aug 28, 2002 11:31 PM
powerstroker250
Jun 10, 2002 08:31 AM
