does anybody out there in truck land know where the tot sensor(trans operating temp)is located?
my o/d light is flashing and i ran the code scanner and its telling me that it is the tot sensor,thanks
93 f-250 deisel 4x4
The TOT sensor is part of the solenoid body assembly. It isn't serviceable as a separate part.
Most likely your problem is the wiring to the TOT sensor. The sensor itself is very reliable. It operates at very low voltage, so it is susceptible to dirty connections.
