injector issue
Old Mar 2, 2023 | 05:50 PM
powerst's Avatar
powerst
4wd Low
injector issue
[size=16px]hi all. this is my first time posting it maybe a little long..[/size][size=16px]So 2 weeks ago i finally did the studs and head gasket on my 6.0 L all when smoothly finished and started driving the truck again. so I roughly pur 240km on the truck and I started getting a code # 6 injector not contributing so I firgure because it was -40c the fuel was gelling.. so I pulled over and turn the truck off erased the code started driving again that code when away then 10 mins after # 3 injector throw the same code. firgure I better go get some anti gelling additive put that in ran er for a hr then that code when away.. a day later took the truck again and noe # 2 injector throw the code plus low Voltage code. so now I though the ficm was toasted, so I had my buddy drop over with his laptop and we ran some test done all ficm test all passed 48v then ran injector test, all injector passed expect #2 it didn't fire on the 3 test we ran.. so I started thinking maybe the wire harnesses for the injectors. so I order one just to try and a new injector for #2..so just wondering if anyone has any other thoughts.. truck had full delete and bully dog tuner..[/size]
Old Mar 2, 2023 | 06:02 PM
bismic's Avatar
bismic
There are no tests that we can do to absolutely guarantee that a FICM is good. That requires it to be sent in so that the logic side can be tested. You could try a known good FICM as an alternative ........
Old Mar 2, 2023 | 06:11 PM
powerst's Avatar
powerst
4wd Low
I think I'm the only one in my town with a truck this old lol. hard to get part. I'd have to buy a second one..
Old Mar 2, 2023 | 06:15 PM
bismic's Avatar
bismic
I hate to hear that. You can send yours in to have it tested, if you do not absolutely need it repaired right away.
Old Mar 2, 2023 | 06:18 PM
bismic's Avatar
bismic
All that said, and I have to admit, I have NO EXPERIENCE in cold weather fuel performance. I can not even comprehend -40.
I do know that fuel gelling impacts fuel pressure to the injectors and low fuel pressure can ruin them.
powerst's Avatar
powerst
4wd Low
oh perfect no I have a second truck this is my hauler . any ideas on where to send it..in Canada preferably.
Old Mar 2, 2023 | 06:19 PM
powerst's Avatar
powerst
4wd Low
the cold is horrible diesel is like jello at -40c and -50c
bismic's Avatar
bismic
Yeah - I looked at where you are from and I can't help you there.
I know that FICMrepair.com tests them, but I have also been told that circuitboardmedics tests them as well. Would be worth a couple of phone calls.
Old Mar 2, 2023 | 06:21 PM
powerst's Avatar
powerst
4wd Low
i here this stuff is great havent tried it yet
Old Mar 2, 2023 | 06:24 PM
powerst's Avatar
powerst
4wd Low
I swap the parts I have coming and if that don't fix it I'll have to send the ficm out for testing and repairs I say maybe a new pcm aswell
Old Mar 2, 2023 | 06:35 PM
bismic's Avatar
bismic
You probably should hold off on the PCM, they RARELY fail.
The Stiction eliminator is for the oil side, and that can also be an issue at your temperatures, especially if you are not using an oil that is rated for that cold weather (ie you should be using a 0W40 IMO).
Old Mar 2, 2023 | 07:29 PM
powerst's Avatar
powerst
4wd Low
right now I'm using 5w 40 but thinking next oil change o w 40 it what we use in are 930 haul truck in are mine. seem to work well in those big trucks
Old Mar 4, 2023 | 04:20 PM
powerst's Avatar
powerst
4wd Low
found #2 injector issue
Old Mar 4, 2023 | 04:27 PM
bismic's Avatar
bismic
That'll do it!
Old Mar 4, 2023 | 06:08 PM
Baykar's Avatar
Baykar
Trailering
You're not alone pal
powerst
Mar 4, 2023 04:09 PM
powerst
Mar 2, 2023 05:40 PM
JClancy01
Feb 28, 2023 08:20 PM
elyrain
Jan 10, 2015 05:40 PM
fordfast
Mar 16, 2005 05:19 PM
