Transfer Case Fluid?
Old Mar 1, 2023 | 03:27 PM
Wbyman22's Avatar
Wbyman22
5th Gear
Hello again,
Is the Transfer Case fluid on these 17+ Super Duty’s the same as the LV Transmission Fluid? I see in the manual it says Motorcraft Transfer Case Fluid, but then next to it gives the part #, which is the exact same as the Automatic transmission fluid part #, which calls for Mercon LV?
I know on my 08 F150 it did call for a specific transfer case fluid and did specifically say not to use the Mercon V fluid in which that transmission called for. I believe Valvoline makes a specific transfer case fluid that met the spec for those transfer cases.
Old Mar 1, 2023 | 04:50 PM
WK15's Avatar
WK15
I used Mercon LV in my 2017.
Old Mar 1, 2023 | 05:22 PM
jimzpsd's Avatar
jimzpsd
Yes, its the same (LV)
Randyholton
18
Jun 9, 2023 08:14 AM
Hunter3006
Mar 20, 2022 01:00 PM
texrdnec
May 10, 2017 06:40 PM
fishbones182
Dec 30, 2015 07:24 AM
stepside64
Mar 26, 2004 11:00 AM
