Sponsored by: Real Truck
Transfer case fluid
Old Mar 12, 2022 | 02:48 PM
Hunter3006's Avatar
Hunter3006
Transfer case fluid
Good afternoon everyone, new to the forum. I have a 2012 f250, 6.7 diesel. The transfer case fluid needs changed. In my research I discovered that motor craft stop making its transfer case fluid and replaced it with Mercon lv. Can someone confirm this for me?
Also what is a good quality brand of DEF fluid?
Last edited by Hunter3006; Mar 13, 2022 at 06:36 AM. Reason: Second question confusing.
Old Mar 12, 2022 | 04:07 PM
00t444e's Avatar
00t444e
Any Mercon rated ATF is fine to use in the transfer case, I use the Supertech brand from Walmart.
Old Mar 15, 2022 | 04:59 PM
Antonm's Avatar
Antonm
Valvoline sells a synthetic transfer case fluid that says it works where Ford XL-12 was originally intended to (see back of bottle)
Amazon Amazon
Old Mar 15, 2022 | 09:45 PM
Boaterguy's Avatar
Boaterguy
If you were to take it to Ford for service, LV is what they would use. It's been in my 2105 for the last 50K miles, and it's fine.
Old Mar 16, 2022 | 06:13 AM
projectSHO89's Avatar
projectSHO89
OP: Any fluid that meets Mercon LV requirements will work just fine in your truck.
Old Mar 20, 2022 | 01:00 PM
Hunter3006's Avatar
Hunter3006
Thanks to everyone for the info.
dant
Nov 16, 2019 11:28 AM
texrdnec
May 10, 2017 06:40 PM
fishbones182
Dec 30, 2015 07:24 AM
flyingtexan
Dec 18, 2011 02:27 PM
Help I M Stuck
Bronco II
May 28, 2008 12:56 AM
