Seems like @Y2KW57 ”recently” gave a very good breakdown for this. I’m hoping he remembers where it might be or at leas a decent way to search for it. Maybe he can provide a copy/paste from his previous post or a link to that thread.
edit: found it.
Method: went to advanced search, then searched for XL-12 and user Y2KW57.
This is confusing. The Redline stuff looks to have better viscosity specs than the Valvoline, but it's ATF, for use in transmissions, so one would expect that. Given that the Valvoline claims to be appropriate for where the no longer available XL-12 was specified, I'm going to go ahead with it. My only goal is to keep the case from grenading itself, which these tend to do. Unfortunately, none of these products say "prevents self destruction" on the label.
I find this issue to be very...um...errr...interesting. Most of the transfer cases in this country seem to be made by the same outfit in Syracuse, NY. I don't remember their name but they all have that round, red ID tag affixed to them. My '91 Jimmy and my '99 F-250 both have one in them and I believe that Dodge uses them too. I expect that they are all about the same inside in terms of engineering and build, with differences in how they mount and electric vs manual. But each auto manufacturer has their own 'special' oil to be used. Combine that with how much the unit is actually used and I'm not too picky about what I put in there.
Ford continues to neglect to provide current guidance on transfer case fluid specifications after discontinuing their Motorcraft XL-12 product, Transfer Case Fluid, and retiring the original Mercon specification.
Ford further compounds their neglect by allowing marketing remnants of no longer produced product to remain on Ford and Motorcraft official websites without notation as to current availability.
I really feel like this is just lubrication for the chain/gears and shouldn’t be so doggone complicated. It’s not like the transmission which needs specific friction modifiers to correctly engage clutch/brake packs. But most of us like to use “the right stuff” for the job.
Ford, why make it so hard to get an idea of a decent lubricant to use?!?
Guess if I ever feel the need to change it I’ll probably use the same Mobil1 that’s in my 4R100.
