Bronco II Ford Bronco II
Rough Running 89 Bronco
Old Nov 15, 2003 | 04:06 PM
savvy5473's Avatar
savvy5473
I have a 1989 Bronco with a 1997 4.0 litre engine.
When I start the engine it idles well for a few seconds and then idles very rough or stalls out. when I step on the accelerator the engine will not rev high..it revy up a bit to about 3-4 000 rpm and then max's out. That is with foot to floor. I have replaced the 02 sensor. I am thinking a fuel problem? I was just driving down the road and all was fine and then all of a sudden she would hardly accelerate.
Old Nov 15, 2003 | 11:28 PM
wolfen's Avatar
wolfen
Welcome to FTE savvy5473,
The 89' bronco has a EEC-IV computer system in it + the 97' uses a OBD-II computer system to power it.
I'd say this is the conflicting problem.
Try pulling the computer codes + see what kind of readings you end up with.
Old Nov 16, 2003 | 12:23 PM
savvy5473's Avatar
savvy5473
It has been running fine since the engine was put in 2 years ago. I would asume that they switched the computer as well otherwise it probably wouldn't be running fine til now.
Old Nov 16, 2003 | 01:51 PM
WeWonIt's Avatar
WeWonIt
How's your fuel pressure? Fuel filter? Fuel pump? sometimes the most simple approach is the best, I'd try those angles before I tried to trouble shoot a swaped engine setup.
Old Nov 16, 2003 | 02:58 PM
savvy5473's Avatar
savvy5473
I checked the fuel pressure and it is 40 psi which is the proper pressure. I pulled the trouble codes and they are
22 Manifold Absolute Pressure Sensor
45 Secondary Air Upstream
66 Mass Air Flow Sensor.
I may have caused the 66 as I unplugged the Mass Air Flow while the engine was running.
Now I am thinking the MAP sensor??
Old Nov 16, 2003 | 06:51 PM
savvy5473's Avatar
savvy5473
I replaced the MAP Sensor. It will idle better now but still will not rev high when stepping on it. What is very odd it that when you first start it, it runs fine and revs perfect for the first 5 seconds and then goes bad from there.
dynarider33
6.4L Power Stroke Diesel
Nov 11, 2015 05:23 AM
OldBlack4x4
Oct 9, 2014 12:42 AM
Broncobudy
1978 - 1996 Big Bronco
36
Sep 24, 2010 02:41 PM
bodyelite
Sep 18, 2002 05:38 PM
