2001 F150 xlt 4.2
219,000
Truck is from Texas with no rust, mostly rebuilt. I found this info. here. What is the mostly likely cause, Is there anything more I should know?
A P0453 code means that a reading from the engine's evaporative pressure sensor is higher than normal, indicating changes in pressure that are out of factory specification.
Faulty Fuel Tank Pressure Sensor · Fuel Tank Pressure Sensor harness is open or shorted · Fuel Tank Pressure Sensor has poor electrical connection · Damaged PCM.
Thanks
