Fuel tank pressure sensor EVAP
Please help 2005 f250 crew cab long bed lariat 5.4 liter V8. Throwing code p0452. Bought a new fuel tank pressure sensor thinking like every other vehicle it would be on top the tank. Dropped it completely down and no sensor any where.. All my research didn't lead me any where. Plenty of f-150 advice but none 250. Please where is this located???
Look on the top of the fuel pump assembly for the FTP sensor, that's where Ford's parts website diagrams show it to be. https://parts.ford.com/shop/en/us/se...-1#partMatched
I've read that on some Fords, it's build into one of the evap system hoses. I have no idea if that applies to your truck or not. Doesn't appear to be a particularly common occurrence on the Super Duty trucks based on web searches I've made.
If the sensor isn't where Ford's own documentation says it is, well...
Did you buy a Motorcraft of aftermarket sensor? Part number?
It's an aftermarket part BWD don't have the part number off hand. Just the amount of disappointment when I dropped the tank and it's not there was not a good time for me I'll get the part number as so. https://shop.advanceautoparts.com/p/bwd-fuel-vapor-vent-pressure-sensor-ec7022/18481767-P?searchTerm=Fuel+tank+pressure+sensor
Part number ec7022
Part number ec7022
2005 Ford F250 EVAP Fuel Tank Pressure Sensor
I believer what you may be looking for is the Fuel Tank Pressure Sensor, Ford p/n 5C3Z9S278GM. It is no longer available. Anywhere that I can find. This sensor is part of a long tube assembly (about 3 ft or so) and is located above the fuel tank in the framework. Yes, you have to lower the fuel tank to get at it! Really stupid of Ford. Alternatively, you could lift the bed, which is really not the toughest job as long as the 8 bolts have not be rusted into place. You are likely better off lowering the tank. I think the actual sensor (a 3" black piece with a connector and tube ports on it, I placed a picture of it for you I have labeled the connector with their function
) part number may be 9C052, but Ford will not have that either. I'm still looking. By the way, it may not be the sensor itself, but one of the tubes that are attached to it. Mine got pinched by the body shop and the mechanic found the problem and once the pinch was resolved no more CEL. The bad news; it a &%$(# to get in there and look for a pinched line. Also, check the connector and wiring. Hope this is of some help. Good luck.
custm42435
1999 to 2016 Super Duty
06-27-2013 01:52 AM
