Sponsored by: Auxito
P0453 code
Old Feb 16, 2023 | 11:09 PM
Michael Lizotte's Avatar
Michael Lizotte
P0453 code
2001 F150 xlt 4.2
219,000
Truck is from Texas with no rust, mostly rebuilt. I found this info. here. What is the mostly likely cause, Is there anything more I should know?
A P0453 code means that a reading from the engine's evaporative pressure sensor is higher than normal, indicating changes in pressure that are out of factory specification.
Faulty Fuel Tank Pressure Sensor · Fuel Tank Pressure Sensor harness is open or shorted · Fuel Tank Pressure Sensor has poor electrical connection · Damaged PCM.
Thanks
Old Feb 17, 2023 | 09:14 AM
jas88's Avatar
jas88
You will get a better response if you will post this in the 1997-2003 forum. This is for 1987-96 trucks.
Old Feb 18, 2023 | 09:02 AM
85e150's Avatar
85e150
Thread moved
ct27gt
Nov 8, 2024 08:30 AM
1968F100ShortBed
2004 - 2008 F150
Oct 12, 2024 04:10 AM
TwittleC
May 1, 2021 03:01 PM
ebford
Aug 15, 2019 03:19 PM
nitro94
1997 - 2003 F150
Dec 27, 2014 05:27 PM
