S&B fuel Tank
I have it on my 2020. It’s been great and 2 issues that I have.
1. It uses the stock float for the fuel gauge. The tank is taller and deeper than the stock tank which means the float stays at full longer and at E there is about 8 gallons left. The float at the top for 200 plus miles screws up the DTE calculation. Not a big deal but….
2. The little valve that keeps diesel from shooting out of the fill while filling when the tank is full is too small to allow filling at truck stops in the truck lanes. It won’t pass enough fuel like the stock one does so it shuts the pump off. I pulled it completely out but now have to wrap a paper towel around the fill neck of the handle to keep it from burping back. Not an issue if you fill at regular diesel pumps that don’t fill as fast. For me it’s an issue while stopping at truck stops with a 43’ 5th wheel.
Other than those, it’s a great tank and love the extra capacity.
Edit: Note that the DTE issue in number 1 is NOT caused by the extra capacity. The capacity is fixed with Forscan or S and B can send you a device to change the capacity calculation. The issue comes from the gauge not moving for so long and the truck still thinks the tank is 100% full. The computer resets the DTE every so often.
The following users liked this post:
I have had 3 of these tanks. All on Ford F350. 2019, 2021 and now my 2022. I think that the product is excellent. I have purchased several things from S&B over the years and have found that all of the items have been great. The customer service is also fantastic. I highly recommend them. The extra fuel is a game changer when towing the Toy Hauler.
Anyone have enough problems with it to regret, and wish you just put a medium sized tank in the bed?
I am VERY apprehensive after reading all the historical threads where people had problems.
I have absolutely ZERO confidence now in people or products. Therefore I try to keep things simple in order to limit the amount of incompetence that seeps into my life from others, and if I have to forscan the truck and then hope that floats work and installers aren't on meth then I know there is a 0% chance I wont have problems.. However at the same time I need the extra fuel for the toy hauler days...
It doesn't matter what you buy - someone always has issues.
I have seen a lot of these tanks installed and nobody has had issues that i personally know. I prefer an in bed aux tank just to eliminate any DTE issues.
Not according to this thread....
The following 2 users liked this post by gSwift:
I have the S&B 60 gallon in my 22 CCSB (stock 34 gallons). Best thing since sliced bread. Yes, the one way valve in the hose is a little restrictive but I can still use the truck stop pumps...you just don't mash the handle all the way. It won't go to the first click and I need to feather it. However, I can still fill it up in just over 3 minutes so, while it's a little annoying, its not bad enough to be considered a major issue. I also wondered if it would work better if it was installed with the pivot shaft vertical? I have not taken it apart to try that theory.
The only other negative is that it "enhances" the SD lean a little bit.
Has anyone tried to install the OEM one?
