Fuel Pump Electrical Issue
Old Feb 10, 2023 | 07:28 PM
Jakester12's Avatar
Jakester12
1996 f150 4.9
Truck sat before I got it, recently put a rebuilt computer in the truck as well as a distributor in chase of spark. Now I have spark, but the fuel pump does not prime or run at all when the key is turned on. If you jump the 86 and 87 wires with the fuel pump relay removed, the fuel pump will run when the key is on. What could be the cause of this?
Edit: fuel pump was also replaced
Old Feb 11, 2023 | 08:56 AM
jas88's Avatar
jas88
Have you replaced the fuel pump relay?
Old Feb 11, 2023 | 09:15 AM
Jakester12's Avatar
Jakester12
no but the relay clicks when you turn the truck on, and the horn also doesn’t work, even though it’s relay seems to be good as well. If you jump the horn relay 30 and 87 the horn sounds.
Old Feb 11, 2023 | 09:47 AM
hobohilton's Avatar
hobohilton
When you jump the wires and the fuel pump runs.... Is it actually pumping fuel ?
Disconnect a the fuel line near the engine and let it flow over into a container. How does the fuel look ?
Old Feb 11, 2023 | 09:50 AM
Jakester12's Avatar
Jakester12
yes it has plenty of fuel pressure, I can bleed a schrader valve near the fuel rail and get good fuel. Fuel tank was flushed very recently too
Old Feb 11, 2023 | 10:02 AM
kenny nunez's Avatar
kenny nunez
Fuel issue
You may not be getting a signal to the fuel injectors.
Old Feb 11, 2023 | 10:58 AM
subford's Avatar
subford
Fuse #16 in the engine compartment fuse box is bad.
Old Feb 11, 2023 | 01:41 PM
Jakester12's Avatar
Jakester12
fuse is good
Old Feb 11, 2023 | 03:29 PM
Prototypemech's Avatar
Prototypemech
Bench test the fuel pump relay and the horn relay with a multimeter and a 12v battery to see if the relays are behaving correctly.
Old Feb 11, 2023 | 07:24 PM
Jakester12's Avatar
Jakester12
ok I’ll try that tomorrow. I was out of town today
Old Feb 12, 2023 | 03:10 PM
Jakester12's Avatar
Jakester12
That ended up being the issue, the truck runs like a top now. Thank you all!
Old Feb 12, 2023 | 03:13 PM
Prototypemech
It's a Christmas miracle!
Replacing them fixed the problem? D​​​​​isregard. I just read your other thread.
Old Feb 12, 2023 | 03:14 PM
Jakester12's Avatar
Jakester12
It sure did.
Old Feb 12, 2023 | 03:22 PM
jas88's Avatar
jas88
I still got it.
Stuart Grantham
Jul 2, 2014 08:22 PM
SoCalJim
May 14, 2014 07:27 AM
rmperrin
1997 - 2003 F150
Mar 30, 2011 06:24 PM
wilsonjoey22
Oct 18, 2009 08:15 AM
htcsusn
Jan 3, 2007 06:57 AM
