Starter Replacement
Old Feb 6, 2023 | 09:46 AM
FindZach's Avatar
FindZach
Starter Replacement
I know theres a lot of data out there on how to replace a starter, from what I see from other people and even from my Haynes manual, it seems like a pretty simple and standard process. Issue I am having is I was unaware that I need to Crimp and heatshrink a connector to something. I went under the truck and took a few pictures of what I am looking at, I am not sure where I should try to disconnect this connection here, it seems like its glued together ; I may just be looking at this incorrectly, but I am not sure where to start with this starter replacement.
Any advice is appreciated, pictures below
Trying to resolve how to handle this wire connection
Thought all I had to do was unscrew and screw back in lol
More view of what im looking at
Looks glued
Apologies for my noobyness
I have no friends who know this stuff, so when I am lost I come here lol; thanks a lot for the help over the last year orso everyone.
Old Feb 6, 2023 | 09:53 AM
jas88's Avatar
jas88
So that starter is not the original starter as that wiring is not factory Ford. Just cut the existing wire before the crimp connector, strip the wire a bit and then crimp the new one on. Use a heat gun to heat-shrink it but if you don't have one, it is not strictly necessary to do that IMO.
Old Feb 6, 2023 | 10:26 AM
FindZach's Avatar
FindZach
When I strip that black wire, do I need to attach some connector to it before connecting it to the new starter wire? Or just crimp it?
Old Feb 6, 2023 | 01:09 PM
Smithda3's Avatar
Smithda3
2nd Gear
Looks like the new starter lead has a crimp connector and heat shrink already on there - just cut your old wire, strip it, crimp it down good with the proper tool and slide the heat shrink over and heat it up with a butane torch or heat gun
Old Feb 6, 2023 | 01:21 PM
Soup bean's Avatar
Soup bean
Here's a link to a video showing details of crimping electrical connectors. I also use an antioxidant on the bare wire before I slide the wire into the connector.
reptar0077
Jan 24, 2023 02:54 AM
TGiordano87
38
Oct 9, 2022 09:28 PM
Newtek
May 4, 2022 08:33 PM
jackhunter
19
Feb 18, 2022 07:20 AM
te47823
Apr 15, 2021 09:18 PM
